09-11-2016, 09:23 AM
trailer wiring
Are all wires in place for 7 way plug in rear and brake control in front on DX3. ? THANKS
09-11-2016, 11:30 AM
Commercial Member
We coil the wires for a brake controller on top of the driver side fuel tank. I think someone on here posted some pictures and their routing path when they installed their brake controller.
10-01-2016, 11:54 AM
Brake control wiring
I got home with the 2017DX3 37RB from MRSRV it does not have any wires coiled on the drivers side fuel tank any other place to look are do I have to try an trace them from the plug ? THANKS
10-02-2016, 11:29 AM
The wires should be coiled "on top' the drivers side fuel tank.
Mike
2016 Force HD
Mike
2016 Force HD 36
10-02-2016, 08:17 PM
I removed the access panel inside the drivers door. They were right there on top of the tank. Easy to route. I did post pics a while back. Maybe look back in the older posts?
2016 Dynamax Force. Just-Rite2
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
10-03-2016, 08:56 AM
They are not on top of the tank on mine and I can't find them anywhere except at the plug on the rear. Any idea's?
10-03-2016, 04:09 PM
Commercial Member
Let me check to see if that is part of our harness or something that we hand wire as a courtesy. If it's had wired, it could have been missed. If it is part of our harness...then, it probably fell off the backside or something.
10-04-2016, 08:35 AM
Commercial Member
Electrical engineer said he has seen where they accidentally pull them across the chassis and up the passenger transition panel. (which I think he is referring to the fiberglass parts where the cab meets the coach). See if there is anything running over there.
10-04-2016, 05:44 PM
I looked there an no trailer wires just step wire and what looks like speaker wires.
10-04-2016, 07:56 PM
Commercial Member
Might have been missed. Not really a published item...they just did it in case someone optioned a brake controller (all unpublished option, which made it easier of course). Now I added a brake controller to the price sheets.
10-26-2016, 06:20 PM
Which brake controller do you recommend?
10-26-2016, 06:25 PM
Commercial Member
We've always run the Tekonsha Prodigy and every time I have asked the question, I get that same response.
10-26-2016, 06:45 PM
The Prodigy P2 and P3 are the most recommended BC on RV forums everywhere.
10-26-2016, 07:18 PM
10-26-2016, 08:43 PM
Thank you
10-27-2016, 06:23 AM
I have one more question which interface harranaass for the 2015 DX3. I look on the web site and frieghtliner is not shown as an option.
10-27-2016, 09:37 AM
Unless you're going to need to take it in/out to use in another vehicle I'd just hardwire it and skip the adapter. It's only like 5 wires to connect. That's what I did.
With a multimeter hand you can test out which wires are which on the freightliner and the manual tells you on the controller side.
2016 Dynamax DX3 - Big Blue
10-27-2016, 11:08 AM
I hardwired it as well. Ran the wires up and into the firewall, came in to the right side of the steering column. One of the easiest projects I did on ours so far.
Making my mod list for this winter. Cant wait.
