Old 06-23-2019, 03:59 PM   #1
Truma water heater not working
Still relatively new with the Isata 3, and preparing for our first real trip. Gas on, Truma switched on in all 3 locations, 1/2 tank of FW, lines air bled, Anderson valve set to dry camping; no hot water. When I dewinterized last month I put the filter in the Truma and all should be good to go. Am I missing anything? All tips and pointers appreciated.
Rich & Karen
West Michigan
Isata 3 24FW
Riverbend is offline   Reply With Quote
Old 06-23-2019, 04:58 PM   #2
milkman55's Avatar
With the water pump on are you getting flow to the sink faucets?
You said itís on at all three locations? I only know of two, one the Truma itself and the rotary dial switch?
You should get water out of the hot water side even if the Truma is not heating. Did you open the valve on your propane tank?
2017 Isata 3 24FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
Old 06-23-2019, 05:02 PM   #3
Thanks M55, you're always quick to help! Water flow from h and c sides at all faucets, propane tank on and full. I have the switch on the heater and the green LED is lit, the rotary in the kitchen and one red lit switch by the step, simply labeled water heater.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-23-2019, 06:08 PM   #4
Is there an amber light on the rotary dial? There should be...make sure the dial is not set to Eco. It takes a minute or two to get hot water if it is.
You may try shutting everything off. Then turn on the switch by the step first. Then the switch on the water heater, then the rotary dial.
Tom and Becki
2018 Isata 5 30FW 4X4
bratbros is offline   Reply With Quote
Old 06-23-2019, 06:21 PM   #5
milkman55's Avatar
One more thing. My toggle switch (the one I forgot to mention) is wired backwards. You might flip it the other position and see if anything changes.
2017 Isata 3 24FW
2014 Honda CR-V
Old 06-23-2019, 06:41 PM   #6
Sandiegodoug's Avatar
Mine is touchy. I found that first I turn on switch by front door, next I turn the sink all the way to hot and run water, finally I turn black round dial up 1 notch and look for the amber light. If I donít do it in that order it doesnít work.
Sandiegodoug is offline   Reply With Quote
Old 06-23-2019, 06:42 PM   #7
Tried the sequencing and no change. Found some hidden lines that were closed when I took the drawer above the switch out, but still no hot water after opening those. I'm going to try the flipper switch in the off position next as it wouldn't be the first thing I've found wired backwards on this rig.
Name:	hidden water lines Truma.jpg
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-23-2019, 07:00 PM   #8
milkman55's Avatar
The closed valves are definitely an issue as they are used to bypass the Truma for winterizing RV antifreeze. It may take a minute to get the flow established. You may have seen water out the hot water side previously, but it was bypassing the Truma.
2017 Isata 3 24FW
2014 Honda CR-V
Old 06-23-2019, 07:01 PM   #9
We have ignition!
Wow...what a crazy little ordeal. Turns out that my rotary switch does light up, but only when it absolutely wants to. I did get the water heater to work, but I really had to play and beg it to start after the first time, which also took a lot of fiddling. I don't know what's going on with that switch but it's sure fussy. And unfortunately out of warranty. Something like that you'd expect and hope to be reliable and simple. I mean I like the concept, and the water got hot real fast, but I had to mess with that rotary switch for several minutes before it decided to light up and send the signal.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-23-2019, 07:04 PM   #10
milkman55's Avatar
Give it a chance, I think it had to do with the bypass valves being closed and after it reestablished flow, it was just a little slow to react.
Your best bet with Truma is to call them directly and bypass dealers. The posts I have read they appear to be very responsive.
2017 Isata 3 24FW
2014 Honda CR-V
Old 06-23-2019, 07:22 PM   #11
Yep
Mine really fussy too. It eventually does work and is much quieter, especially on cold nights.
Old 06-23-2019, 08:58 PM   #12
chroniekon's Avatar
It seems to help turning the rotary dial off, and then back on. And to have a faucet turned on in the hot position.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 06-24-2019, 12:19 PM   #13
LandKKnight's Avatar
Seems like you got it working so this might be after the fact, but I have to make sure the propane is bled through the lines, too, by turning on a burner at the stove first, so I know the propane is getting to the water heater. If I don't do that, the water heater doesn't ignite. If I do it, you can hear the water heater turn on immediately. Otherwise I'm waiting awhile. Also, I have had to turn the rotary dial on and off a couple times as well to get it going, especially if its been awhile since I used it.
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
LandKKnight is offline   Reply With Quote
Old 06-24-2019, 12:24 PM   #14
I did light a burner for that exact reason! I love the on demand concept and hope it becomes more reliable as others have suggested.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-24-2019, 12:38 PM   #15
I had similar problem with amber knob switch. computer module bad an Truma replaced free. call Truma with s/n
Mocha Magic is offline   Reply With Quote
Old 06-24-2019, 05:32 PM   #16
Same problem with the 'fussy' amber light. It appears to work when it darn well wants to after redoing the same steps a couple of times in the order they mention. Will try the kitchen faucet for hot water method next time and see if that works....if so then I will follow that each time or if not follow the advice and check with Truma for module. I have yet to get it to work first time through and I have had our Isata 3 FW for over a year. Once on though it works like a charm.
Retired Army CWO//DoD Army Civilian//2018 Dynamax Isata 3 24FW, Apr 13 2018
ferrisjc is offline   Reply With Quote
Old 06-24-2019, 05:37 PM   #17
Now I'm working on getting the fridge cold. 6 hours on propane and the freezer is pretty cold but the fridge is still in the high 50's on the coldest setting. And I put a few ice packs in it to hasten the process.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-24-2019, 05:52 PM   #18
On propane only your cool down times are going to seem long, depending on the outside and starting temperature. Normal.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 06-24-2019, 06:10 PM   #19
Our Minnie Winnie would chill in about 3-4 hours on propane, but it was about 30% smaller. This Dometic freezer could make ice after 2 hours, so I found the fridge temp surprising. Still getting used to this I 3.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-24-2019, 06:49 PM   #20
I also experienced the finicky Truma rotary knob, I can move the rotary from Off to On (Comfort) or Eco position and get no amber light so itís not actually on, but just jiggling the knob very lightly until the faint amber light comes on does the trick. Click image for larger version
acoxFL is offline   Reply With Quote
heater, water, water heater
