09-21-2018, 06:31 PM
Update on Dynamax XL 37BH
Freightliner engineering is now looking at the issue with the vibration during acceleration...it looks like I am in for the long haul...may have to replace the rear end...
09-21-2018, 06:35 PM
I had a Dynamax on a M2 chassis and they replaced the rear end because of vibration and gear noise. No problems since...
09-21-2018, 07:24 PM
How many miles did you have on it?
09-21-2018, 08:11 PM
About 10k as we noticed the noise early. I had to fight and finally took the service guy for a ride and then he knew it was legit. We sold it after 85k and really enjoyed the coach and M2 chassis.
09-21-2018, 08:14 PM
Mine has been doing it since I received it with 1000 miles on it...they wanted to pass the buck onto me, Dynamax and then the Dealer, but I wasn't going to let that happen, it ain't over till it's over...
09-21-2018, 09:27 PM
Wow... wish I was so lucky, have a similar problem. Tech at Ram called for the rear to be replaced too, but FCA said no. Tech has worked for them for 38 years, he was shocked.
09-21-2018, 10:52 PM
A clear veteran tech says it needs a rear end and FCA declines it.....now what?
09-21-2018, 10:56 PM
So how do they explain a rear end going out with few miles? Seems like a assembly QC issue to me.
09-22-2018, 05:24 AM
It got pass Freightliner, Dynamax, and the Dealer....it's about selling it's not about quality anymore...it's about whatever they can get the consumer to accept and increase their bottom line...they can't even spell quality anymore or attention to details...
Then the Dealer said there was nothing wrong with it, then Freightliner in Tyler Texas said the same, then back at the Dealer and they took it to Freightliner Dallas South, thats when they found a REAL mechanic that located the vibration and started the process of elimination...he mentioned the rear end may be the culprit, we're still waiting on Freightliner Engineering to respond...
Almost a year from ordering the unit...have camped in it once...lol...
09-22-2018, 08:42 AM
Good question... still fighting it out with FCA. Both the service manager and tech were shocked.
09-22-2018, 09:50 AM
Time to write letters to "Motorhome" or if members, Good Sam. FMCA?
09-22-2018, 11:34 AM
And the purpose is - - - ?????
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
09-22-2018, 11:57 AM
I've seen their results...manufacturers don't like negative reports and seem to respond positively when prompted by staff from these valuable sources.
09-22-2018, 01:15 PM
It seems that after a very long wait the OP now has the right people looking at the problem at Freightliner. The Jury is still out if the latest effort will be successful, but at the moment it is kind of premature to start complaining to the big magazines.
2019 Rubicon JLU
09-22-2018, 05:21 PM
Curious as to what the solution will be. Would like to know what, on the ream end, is defective.
09-23-2018, 01:02 PM
While I understand your frustration and believe you are entirely owed the correct repair for your problem, I respectfully disagree that it's not about quality any more.
I say that because out of all the thousands of units sold, you're going to have something that isn't right. There isn't a product I can think of that has a zero complaint ratio. Hell, I can't even buy an iPhone without finding the 1/32 billion sold ending up in my hands.
These are motorhomes, they are mobile homes on wheels and are going to have problems. I think it's evident that the quality of these RV's from Dynamax are head and shoulders above other RV's but at the end of the day, they're gonna have problems, plain and simple.
I hope you don't have any other problems with it but I'd hardly call the half a dozen people that have rear end problems out of all the ones sold, "poor quality".
Just sayin'
Mark
09-23-2018, 03:07 PM
Just sayin'
Mark
Respectfully, we'll have to agree to disagree, this serious vibration should have been addressed LONG before a consumer received the unit...
BUT one thing for sure if I did this again, I would make dang sure I went to the factory before I ever accepted a unit...and the reason being folks go to the factory? Because you can't trust Dynamax or their Quality Control standards, this is stated many times in this forum from all the folks that go there...they don't go there for cakes and balloons they go so they can perform Quality Control on their respective unit and to INSURE that Dynamax does what they state in their website: Attention to Details...
09-23-2018, 03:10 PM
In process...like I told them from the beginning when they wouldn't listen, I can be the best advertisement or the worse, they have ever had...looking like they don't mind the latter...
09-23-2018, 03:57 PM
Has anyone checked the pinion angle? When I was building race cars and setting up driveline orientation. U-joint angle was the most important measurement to insure no vibration. Drivetrain vibrations eat horsepower.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
09-24-2018, 07:04 AM
Yes sir, thats the first check the Master Tech checked everything was within 1 degree which is within spec...they did adjust the swing or carrier bearings to true alignment as well...they also adjusted and confirmed the ride height was within spec...
