Old 06-19-2018, 10:05 AM   #1
UVWR info available?
Am I missing something? I can find lots of info on the GVWR and GCWR of a given make/model, but I can't seem to find any specs on where a given model typically starts before any additional items are loaded (UVWR). This would seem like very useful information to have in the buying process, but it does not seem to be in any of the brochures and the one sales guy I talked to was not aware of the unloaded weights either.
I understand that options and layout would impact the weight greatly.. but besides pulling it onto a scale...is there any general unloaded weight information available. Maybe I'm just missing it.
wfo9 is offline   Reply With Quote
Old 06-19-2018, 10:17 AM   #2
Gsykora's Avatar
If you're talking about the RV, there should be a sticker in the door jam that shows the exact empty/dry weight of the rig as it came out of the factory. Here's ours from our CC36CK2 - its' pretty darn close to the factory spec sheet.
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
Gsykora is offline   Reply With Quote
Old 06-19-2018, 10:22 AM   #3
MillMitch's Avatar
I haven't had a lot of luck either. Sometimes you can find curb weight online. Or if you can find the payload, you can back into curb weight by subtracting the payload from GVW.
good luck.
edit: i was thinking TV
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 06-19-2018, 12:24 PM   #4
GM
bclemens's Avatar
The weights are all over the board depending on options. For instance...what do I put on the brochure? a 36DS with no options 4x2 or 36DS with all options and 4x4 for a worse case scenario? In the end....every vehicle is weighed, subtracted from the GVWR and CCC posted. Yellow sticker on the driver side jamb of the cab door in most cases.
Any particular model/brand you are looking for?
When you say "one sales guy"....dealer sales guy? All they would have to do is open a door and look.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-19-2018, 12:36 PM   #5
Like the mystical "dry" weight UVW is totally useless for all but a salesman to help sucker a unsuspecting buyer.
donniedu is offline   Reply With Quote
Old 06-19-2018, 12:44 PM   #6
FOURWHL's Avatar
If you’re still looking at the M2 sized trucks I can at least tell you it’s not terribly important. You’ll have more CCC than you know what to do with. On my 37BH I want to say I’m around 24-26k empty with a GVWR of 33k.
More importantly when I was completely loaded up, with the Jeep on the trailer this was my weight. Plenty of room to add more crap if I can find some.
Obviously you’re mileage may vary but it’s at least a ballpark
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 06-19-2018, 01:30 PM   #7
I'm mainly looking at the ForceHD/DX3 vs Verona LE.... The door jamb is easy enough and was just something I was missing.. I wish the salesmen would have known that as it should have been easy info for him to get.
In my experience with other things.. weight always matters in the end. So I just wanted to know where I was starting with on different models/options... I won't use unloaded weight as my deciding factor.... but I think it is valuable Intel when comparing floor-plans and options....
Old 06-19-2018, 02:27 PM   #8
GM
bclemens's Avatar
What THE brian said. If you're on an M2 truck...you would be hard pressed to use up all that capacity.
Average UVW on the Force is about 25,000 lbs
Average UVW on the DX3 is about 26,000 lbs
Old 06-19-2018, 02:52 PM   #9
FOURWHL's Avatar
Whoa whoa whoa just because you run the place that makes me the other Brian??!?
Iíve said it all my life... there are entirely too many Brians
Old 06-19-2018, 03:01 PM   #10
GM
bclemens's Avatar
What in the world could you be talking about?
