Old 04-22-2018, 09:12 PM   #1
AWF1945's Avatar
Warning must see
If I hadn't been on the coach today it would have burned to the ground. Check your seal around the cap. During a heavy rain water came in through a small crack then ran down wires onto one of the receptacles located in the entertainment compartment below causing it to short out and catch fire. Luckily as I stated... I was here and took quick action. Turning off main power. But that wasn't enough, the receptacle shown is powered by inverter.
Once that was shut down was able to smother the small blaze. My lil pet Twiggy was inside too... I thank God I was here.. my wife was out shopping. While you may think this is rare, it is not.. I've already survived a bus fire , I don't need another. CHECK YOUR SEALS.. THIS IS CRAZY!!!Click image for larger version
ID:	169244Click image for larger version
ID:	169245Click image for larger version
ID:	169246Click image for larger version
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 04-22-2018, 09:18 PM   #2
Who Dares, Wins
doc73's Avatar
Well that is frightening.. Glad you are okay and where there to catch it!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-22-2018, 09:38 PM   #3
Wow thankfully you and your pet are ok. Probably best your wife was not there and was out shopping. That is scary..
2019 Dynamax Force TSHD
Mountieman is offline   Reply With Quote
Old 04-22-2018, 10:50 PM   #4
AWF1945's Avatar
Very scary.. I'm still in shock
Old 04-22-2018, 10:59 PM   #5
Are you still in the coach for the night? Didn't really know the extent of the damage or if they wife made you get a hotel for the night?
Old 04-22-2018, 11:07 PM   #6
dlfishing's Avatar
Thatís disturbing, I wonder why a breaker didnít catch that? What is the location of the photo on your cap?
dlfishing is offline   Reply With Quote
Old 04-22-2018, 11:32 PM   #7
AWF1945's Avatar
I asked the same thing of an electrician I know... he said, ya ever heard of GFI .. well if they ain't GFI... There gonna fry when wet. The stuff that goes on in building these coaches are not regulated by codes. He went on with his comments about wiring and... well I'll leave it there. He doesn't care much for the standards in the industry... says it's a joke.. his opinion not mine. However, i agree in certain areas for sure.
Old 04-22-2018, 11:37 PM   #8
cavie's Avatar
A breaker will not trip until there is a short from hot to ground or neutral. The burning insulation may burn back neutral and ground wires and short them out but that will not trip a breaker. Only hot to ground or neutral will trip the breaker. A lot of plastic can burn before that happens.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-22-2018, 11:45 PM   #9
AWF1945's Avatar
A lot of plastics will burn along with wood, insulation and other flamilble materials... don't underestimate the lethal process ... it can go guick.. in a blink of an eye... ARE YOU AND YOUR FAMILY PREPARED...
Old 04-23-2018, 09:23 AM   #10
AWF1945's Avatar
Yes I did repair. Aired coach out good, cleaned out leaky seal resealed with urethane. Cut wires back to good copper reconnected using water proof twist connectors and tucked away nicely. I will not reinstall another receptacle as it was not needed in my case. All cleaned up, back in service.
Today I'm resealing the other side which appears to have the same problem. They look good until you get close. And, if the rain is coming in just right as it was in my case... water will find its way in and land where the path takes it. The factory may want to consider butyl tape in between as apposed to nothing other than just sealer that fails in a short period of time.
CHECK YOUR SEALS FRIENDS. I CAN'T STRESS THIS ENOUGH... CHECH YOUR SEALS!!Click image for larger version
