Is it possible to retrofit the bunk area of an Isata 5 35DB and put either a washer and dryer side by side or a combo unit?
If not, is it possible to retrofit the bunk area for storage? That is, is any part of the bunk structure essential for the structural support of the bunk slide out?
Put in a w/d? Not likely. That is unless your prepared to add water, both hot and cold, a drain tapping into the gray tank, and now adding a dedicated 120VAC plug.
Rip out the bunks for storage? Easy, take em out.
Thanks. Seems like a lot of work seeing as the water is all on the other side of the coach. Seems to me I can just enjoy the sofa and put baskets in the top buck area for storage. LOL
