Old 07-27-2016, 03:38 PM   #21
RV Control Panel
kathybrost is offline   Reply With Quote
Old 07-27-2016, 04:12 PM   #22
GM
bclemens's Avatar
Ignore the tank heater....that is a heat pad for the black and gray tanks.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 07-27-2016, 05:07 PM   #23
Ok, and just to clarity, with the Tankless Water heater, does that only work off of Propane? Or does it work if just plugged in, or Generator? I am going to open the box where the heater is tomorrow and look at the things suggested here. If it only works off of propane, where do I turn on propane. Geeze, everytime I think I know a thing or two there are others that I don't know.
Old 07-27-2016, 06:31 PM   #24
Love my Rev
pretty sure it only uses propane to heat water
Originally Posted by steve32409 View Post
very simple system - turn red water heater switch on ( as you come into back door ) and open any hot water valve ! ( if not hot real quick - first check the small on /off gas switch behind outside door where lp gas is filled and that is on ,- then take screwdriver or penny to back of water heater ( black metal cover left of outside shower ) and push little red breaker in the top left of that compartment
do this and will work ?
steve32409 is offline   Reply With Quote
Old 07-27-2016, 06:35 PM   #25
Love my Rev
check your lp gas button ? in your picture
lol - you do have lp gas - right , and in that picture the water heater switch is in the off position
Old 07-27-2016, 06:58 PM   #26
RSchleder's Avatar
Try this linc, it should give you some basic info to build on.
New RVer
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-27-2016, 10:13 PM   #27
Ok, so here is my Panel by my RV door. So, first I need to make sure I am doing the right thing. If I have a tankless water heater, is the only way to use it with Propane? Or can I use it via generator or plug in? I am always confused on what can be use with what.
Next, so lets say I want hot water. I make sure the red button is on and then turn on hot water from the faucet? Do I need to do anything with the button that says Tank and Heater? What is the difference between the Tank/Heater and the Red Water/Heater button.
Help!!! Getting there...
Mine works on both gas and electric.
To work on gas you have to have propane in the propane tank and the propane switch must be in the ON position. The propane switch is next to the propane fill valve on the left side of you REV.
It should work on electric if you are plugged in to shore (house) power. I am not sure if your battery toggle switch needs to be on or not for that to happen. If not plugged in to shore power then I believe you can get hot water if your battery switch is on and you have water in your fresh water tank and you have your hot water switch on.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 07-28-2016, 07:42 AM   #28
GM
bclemens's Avatar
Delco Bobby...your's is a 2017 with the Truma Combi. The 2016's had the Atwood ON-demand.
Old 07-28-2016, 08:46 AM   #29
Love my Rev
for those who have a 2015 model
the small overheat breaker ( push in ) if you hear it click , then problem fixed and when you use hot water - turn fully on and not half way.
Old 07-28-2016, 08:53 AM   #30
halla's Avatar
Not sure if it has been mentioned, but did you check to make sure the LP Gas is turned on at the tank?
Sorry if this was already discussed.
halla is offline   Reply With Quote
heater, water, water heater
