Old 07-26-2016, 02:11 PM   #1
Water not turning on and water heater?
I have gotten such valuable info here, and considering I am a newbie at this I have lots of questions.
So, water tank shows full. However, I can't seem to get any water to come out of sinks, or toilet. What do I need to check? First thought was maybe air in the lines? Otherwise, I don't know, do I turn on a pump? I have the REV 24RB plugged in right now. Can you give me some ideas on where to trouble shoot?
Thanks,
Kathy
kathybrost is offline   Reply With Quote
Old 07-26-2016, 02:19 PM   #2
Is the pump switch turned on?
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-26-2016, 02:26 PM   #3
Yep, should be a pump switch somewhere in the trailer. If not on city water you have to have the pump on.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 07-26-2016, 02:42 PM   #4
Ok, I did turn the pump on at one point but nothing came out, unless I have to wait a bit longer or something. I will take a photo of my wall switches
Old 07-26-2016, 03:12 PM   #5
Are your winterizing valves turned to normal use or still in winterizing mode?
2016 Flagstaff 23lb
Old 07-26-2016, 03:39 PM   #6
I don't know what winterizing mode is. We have used the water and hot water just fine. My husband filled the tank last time and all I can think of is maybe he didn't make sure there was no air in the line?
Old 07-26-2016, 03:44 PM   #7
Do you hear the pump running? Has it worked in the past?
2016 Flagstaff 23lb
Old 07-26-2016, 03:55 PM   #8
I have, and now that you say that I didn't hear it turn on. Is there a plug or anything for the pump?
Old 07-26-2016, 05:39 PM   #9
halla's Avatar
Might have blown a fuse or tripped a breaker.
2016 Dynamax Force. Just-Rite2
2018 Dynamax Force HD BH---Just Rite-2
halla is online now   Reply With Quote
Old 07-26-2016, 05:58 PM   #10
Flybob's Avatar
Do you have lights and fan? What is battery level?
It you get pump running, it may take 30-50 seconds to get water from cold faucet. Make sure the low point drains ( Red and Blue lines sticking out bottom of RV ) are closed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
heater, water, water heater
