Slide tracks could be the source
If you have the external tracks at the bottom of the slide, you might want to look closely at the rubber seal when the slide is out. I was having a minor water leak in a different brand of trailer and it was from water running down the track and back into the trailer. The rubber gasket couldn't seal tightly enough. The dealer told me to put some silicon in that void and it took care of the problem.
