Old 08-19-2018, 07:34 PM   #1
chroniekon's Avatar
What Tail Light System for Isata 3 Toad
I have a 2004 Jeep TJ I'm setting up to tow behind my Isata 3. I have the tow bar and brake system for it, but still need to come up with a light setup for the tail lights. What works best for you?
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 08-19-2018, 08:56 PM   #2
milkman55's Avatar
I installed the Blue Ox independent light bulb kit in my Honda CR-V because I didn’t want to mess with diodes and tapping into my Honda light wiring. Real simple install, just drilled a 1” hole in the light housings and installed the bulb holders. Ran the wire underneath to the front plug.
You might want to read the thread about issues with the Isata 3 tail light controller where some people have had issues with losing tail lights with a Toad.
I just drove 2,500 mile with my setup and had no issues.
https://www.rvupgradestore.com/Bulb-...9-p/bx8869.htm
2017 Isata 3 24FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 08-19-2018, 09:28 PM   #3
chroniekon's Avatar
The guy I bought the braking system from had that setup on his Honda toad. I really like that idea, but I'm not sure the Jeep has enough room inside the tail light housing for another bulb. Do you have two bulbs lighting up on each side when the brakes are applied? The stock Hondas and the added Blue Ox ones?
2017 Isata 3 24FW
2004 Jeep Wrangler
Old 08-19-2018, 10:14 PM   #4
milkman55's Avatar
Actually three bulbs on each side, a tail light, brake/turn signal and then the bulb I added which has two elements for tail, turn and brake, all in one bulb. The housings are quite large and easily accommodate the extra bulb.
You can also consider the magnetic add on lights which are also independent from factory wiring. They come on both wired and wireless types.
2017 Isata 3 24FW
2014 Honda CR-V
Old 08-20-2018, 03:01 PM   #5
I built a light bar that goes onto toad receiver and ran a wire to front with connectors on both ends. Just like a trailer connects.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 08-20-2018, 05:56 PM   #6
I used Hopkins toad wiring on my 12 Liberty. Where the Jeep wiring harness plugs into the light, the Hopkins harness plugs in between the two. Very easy to install. I got mine from RV Upgrades. It costs less than the others too.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
FrankMor is offline   Reply With Quote
Old 08-20-2018, 06:58 PM   #7
Some tap into the stock lights right below the drivers door. Using 4 wire trailer plugs, you can have one set to connect the existing wires, and one for a new connection for towing (which go out the bumper to the MH).
Personally, I use wireless magnetic, as the stockers in our jeep also trigger when the ready brake system engages. The magnetic also work for when we dolly our other vehicle instead of bringing the jeep, and can be used on the back of a hitch rack (on MH, or either towed vehicle).
2016 SS 2250 E450
Dp26 is offline   Reply With Quote
Old 08-20-2018, 07:01 PM   #8
Hi, check the Roadmaster web site! They have wiring kits for many toad vehicles. I got mine from them for a Lincoln MKX and had it installed. Works great.
Doug Eichel is offline   Reply With Quote
Old 08-20-2018, 09:33 PM   #9
I got the cool-tech JL lighting kit. I believe theirs on for JK too. No need to run wires to the back. All done by passenger seat with a switch. Relatively easy to fit
Motorhome1 is offline   Reply With Quote
Old 08-21-2018, 05:29 PM   #10
chroniekon's Avatar
Thanks for all the replies everybody. I've ordered some parts to try and see if I can get an independent bulb setup inside the Jeep tail light housing. Sort of like Milkmans #2 post above.
2017 Isata 3 24FW
2004 Jeep Wrangler
light, toad
