Originally Posted by chroniekon
I set mine up myself. I was able to find the major components on Craigslist. I have a very basic tow bar by smittybilt. The braking system is a Blue Ox Patriot. It's not as convenient as the built in braking systems as you have to put the 'box' in the rig and plug it in, it maybe takes a minute to set up. And you have to find a place to store it when not in use. I fabricated a version of Roadmasters Defender rock guard. All in with all the extra lighting, electrical, safety chains and hardware, I'm a little under $450.
Sounds like you are pretty happy with the Blue Ox Patriot portable system. How are you powering it in the CRV? Did you have to install a 12 volt outlet for it or just use an existing 12 volt outlet? As I understand it from milkman55, if you upgrade the battery and/or install a charger, you don't have to pull any fuses.
