Recently purchased a 2018 Force 37TS.
The small wooden compartment over the cab on the P/S front corner is empty other than 3 cable cords, a HDMI cord and a small plug in transformer attached to the 110 outlet with a small wire running down under the bunk into the cab(not sure what it powers? Assuming it should have a switch box but not sure.
the forward most compartment has a removable bottom. maybe a trim/putty knife can pry that up.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
depends on what cabers you are referring to. Coax won't. But as mentioned above, you can put a receiver in there (which is likely what came out)
