Old 07-07-2016, 08:26 AM   #1
FOURWHL's Avatar
Window Knob
So it seems one of my windows was sticking and when I tried to open it I may have stripped something. When I go to close it now I'm able to feel something slip and it keeps turning. I can get the window to a "snug" point and it'll stay closed for a little bit but after a while down the road it starts flapping.
Haven't taken it apart to see exactly what's up. How hard of a fix is this? Is there a place to order parts or do I need to go through a dealer?
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 07-07-2016, 09:23 AM   #2
GM
bclemens's Avatar
Those knobs screw on...I think the shaft is metal, so it should be the knob that stripped (crossing fingers). Those are Kinro windows. 3000 series. Typically through a dealer to get parts or direct to Kino if they sell direct.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-13-2016, 11:50 AM   #3
Hey FOURWHL,
I had the same issue with the window in the forward Bunk, a blue DX3 flew by at 80+mph on the Interstate Hwy70 in Co. and my window flew open.
You wouldn't know who that might be would you ?
It had happened on my way home from TX as well. The screws holding the Knob(s) were loose on more than half the widows, you're going to have to check them all. On the sticky ones, I used armor all on the rubber and that did the trick.
2016 Dynamax Force 37BHHD
724Bravo is offline   Reply With Quote
Old 07-13-2016, 12:50 PM   #4
FOURWHL's Avatar
Was that you I passed?!
At least the Wife and I both waved
Old 07-13-2016, 04:53 PM   #5
halla's Avatar
I ended up using blue loctite on the knobs. I also used it on the sliding doors and the shower door. We had a lot of screws work their way loose, blue works great, no more screws falling out. Dont use red, it requires heat to break it loose if you need to remove the screws.
2016 Dynamax Force. Just-Rite2
2018 Dynamax Force HD BH---Just Rite-2
halla is online now   Reply With Quote
