Old 05-07-2016, 01:30 PM   #1
Window rubber moulding
Wondering if anyone has experience with re-sealing the rubber moulding around the window base of my doors. For some reason, the rubber moulding is coming loose on both of my doors. The sealant used at the factory appears to be a yellow color.
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 05-07-2016, 08:04 PM   #2
AWF1945's Avatar
Looks like 3m weatherstripping glue. And thats a mess! A real pain to clean up.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is online now   Reply With Quote
Old 05-07-2016, 08:27 PM   #3
cphubert's Avatar
Yes, mask off other surfaces, clean with acetone and clean rags and a plastic scraper (it will also clean / remove light layer of the trim - will show as black residue on the rag) reseal with 3m glue follow the instructions on the tube most auto supply's carry it . I remove masking after cleaning and apply new masking close to trim and do not remove masking until after the trim if clamped and cured, any squeeze out will be on masking not on your finish surface. Hope this helps you might find it being applied on YouTube. Yes it is a pain to clean up after.
cphubert is offline   Reply With Quote
