Old 05-17-2019, 07:03 AM   #1
jdebevec's Avatar
Windows shake like they're gonna fly off
I've searched the forum to see if anyone has this same problem, but came up with nothing.
The frameless windows in our 2018 I-5 DB seriously shake, or vibrate in and out when you get up to highway speed. With the window fully closed, the glass flexes in and out in the center at a high rate of speed from the buffeting of wind. So when you are going down the road, the glass itself makes noise, there's a lot of wind noise, and you can even see through the gaps. It gets so bad it seems like they're going to just rip off the side and land in Kansas.
I've checked the adjustment of all the windows, and the glass makes firm contact with the rubber seals all the way around when stopped. The crank stays closed tightly, no issues there. Even cranking it shut as tight as you can (up to the point of breaking the crank) the glass still flexes.
I've finally resorted to taping the windows shut to the rubber seal with industrial strength tape. No more shaking and noise... but of course I can't use the windows.
All of the windows are doing this, on both sides of the coach. I haven't taken it to a dealer yet, I like to troubleshoot on my own first and go to a dealer as a last resort. I've seen several posts about double pane windows, but short of replacing all of my windows does anyone have any ideas?
jdebevec is offline   Reply With Quote
Old 05-17-2019, 07:54 AM   #2
GM
bclemens's Avatar
Contact customer service rep and get it to a dealer.
Dynamax - Manufacturer of Luxury Class C & Super C Motorhomes
I had this on a Solera back when I was at Sunseeker and we used Hehr windows. When a single glass pane gets too big (ours are actually smaller than what I had the issue with at Sunseeker), the glass can actually flex. Especially if there is positive pressure in the motorhome. I suspect that if the AC is on you can be creating that positive effect...we don't have the vents in the back of the cab. It doesn't always happen BUT, once it starts, I personally think it weakens the pane and now its just plain flexible.
Hehr's solution was to send a thicker pane of glass and trim. Drill out (3) rivets, place the new glass, re-rivet. done Solved 100% of the issues.
Flash forward to today...LCI has no desire (they also own Hehr now) to make that change and claims it is not their issue.
We have redesigned many of those windows to have a smaller vent section (9" vent). That seems to have corrected the issue.
The other thing you can do, if looking at local fix or temp fix, is adding more rubber seal under the pane. Or a larger trim/seal in front of the pane. That prevents the wind from getting underneath the glass to add to the positive pressure in the motorhome. Once the buffeting wind starts it, you are increasing the air pressure inside, which then just push the window out more.
Sort of like when you open a rear window in a car, but not the front.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-17-2019, 08:26 AM   #3
Commercial Member
ES_FR's Avatar
jdebevec,
Thank you for being a part of the Dynamax family.
Please accept our sincerest apologies for any inconveniences that you have experienced with your new Isata 5. Your satisfaction is very important to us; accordingly, we invite you to contact Dan Dobecki in our Customer service department through the following personalized and direct link: Dynamax RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is online now   Reply With Quote
Old 05-17-2019, 08:30 AM   #4
GM
bclemens's Avatar
lol....looks like I'm even faster than our Bots
Old 05-17-2019, 08:38 AM   #5
caseymyers's Avatar
You never sleep, those BOTS are down for maintenance at night.
Old Navy Chief
2019 Isata 5 DS 4x4
2015 Jeep Rubicon Toad
Days camped in I5 2019 = 26
caseymyers is offline   Reply With Quote
Old 05-17-2019, 08:47 AM   #6
FOURWHL's Avatar
I always knew he was part robot....
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 05-17-2019, 08:54 AM   #7
Awning windows use a torque operator to open the vent. The operator has arms that should extend the full width of the vent glass. Sometimes shorter arms are used to limit the opening distance, or maybe the wrong arms were applied, and this prevents the outer edges of the glass from being able to be properly tightened against the seal and frame. Most RV glass is 1/8" tempered and, as Brian mentioned, it is very flexible.
Without seeing the window I'm just guessing this may be the cause but check the arms to see if they're going the full width of the vent panel. If not, the operator can be swapped for one with longer arms. Another option is to bond a stiffener rail to the glass just above the awning arm slide channel to limit the glass flex.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2 4.30
woo10-210 is online now   Reply With Quote
Old 05-17-2019, 09:42 AM   #8
Interesting....I had a bathroom window mysteriously shatter and disappear on one of the first camping trips I took with my I5 30FW about a year ago. I turned it in on my insurance since the shattered glass scratched one of the cargo compartment doors and the new window was over $500+labor to replace. Could this have been what happened? I haven't had a problem since.
Tom and Becki
2018 Isata 5 30FW 4X4
bratbros is offline   Reply With Quote
Old 05-17-2019, 09:45 AM   #9
GM
bclemens's Avatar
We haven't had that issue with a bathroom window as it is much smaller.
Old 05-17-2019, 04:15 PM   #10
Do you have a 35DB?
If so, is it the emergency escape window by the dinette?
If so, yes that window looked like a bass kick drum on the road and caused a pulsating noise inside. It's because the emergency latch would not clamp it down tight enough for a seal and the glass itself is rather large. On our one and only trip it let air in and we thought it would break the entire time when driving over 55. I put tape on it to seal it, but it still pulsated.
Mine was replaced with a completely different window, fixed glass like above the couch with the crank out awnings below.
dannko is offline   Reply With Quote
window
