Originally Posted by twp5253
If I really want the Winegard® Trav’ler Stationary Triple LNB Satellite Dish on a DX3, can the Connect 2 be removed and replaced with the Trav'ler? Or should I make sure that option is on the coach before I buy it? And don't even mention that its a stock option on the Dynaquest.......
Not sure why you would want to replace the Connect2. Those are two different devices. You would want to ADD the Trav'ler.
The Connect2 is wifi, cell & OTA.
Trav'er is Satellite only.
The T4 in-Motion is standard, so you could pull that and install the stationary sat, but the only reason for that really is HD on DirecTV.
