Originally Posted by Tom2129
Can anyone give me any info on winterising my Isata 5?
Tom....
I posted this in another wintering post. I used compressed air. Will add comments below if you use RV antifreeze.
- drain water from fresh water tank
- pull out water filter
- open low point drains. Open faucet. When done close faucet
- follow winterizing instructions for Truma hot water heater
- blow out water lines, including ice maker, outside shower handle and toilet line. Use 40 psi and leave connected over night and run ice maker. ( buy a fitting to connect to city water and assumes you have a compressor where the psi can be set
- pour RV antifreeze in the drains including toilet.
- drain grey and black tanks.
- full tank of diesel. I put in a cold weather additive.
- check tire pressure
- put in mouse traps just in case there is an uninvited guest
- put in moisture absorber
- make sure coach batteries have full charge then disconnect batteries using disconnect switch
- disconnect the two vehicle batteries.
If using RV antifreeze in water lines:
After winterizing Truma, remove the lower false drawer front in the bed room and close the valves to bypass the hot water heater. Then you need to tap into the water line running into the water pump. You can buy a wintering kit or a hose with a fitting. Turn on the water pump using hose to suck up RV antifreeze. Run through all lines including ice maker. Pour rv antifreeze down the drains.
Other will have adds and good comments based on what they do.
