I finished the winterization valve project. I have attached a few pics to show before and after as well as the part that I used. The project was pretty straight forward with the only change to the instructions being that I put the valve directly on the fresh water tank, so it would winterize the intake filter too. I did have to slide the water tank forward a couple inches to make room for the additional length. I now have a simple way to winterize since we usually do this several times a year (we take trips all year). With this all I have to do is open low point drains, fresh water drain, and pull the water heater anode. once it is all drained I close the valves and turn the water tank bypass valves, and turn this new valve into the winterization position. Turn the water pump on and place the draw hose into the pink antifreeze jug. Run faucets, shower, outdoor shower, and commode until I see pink. DONE
