Blow out the system, and blow out the reefer water dispenser if you have one. Leave the pressure on overnight, let the reefer run and you have blown out the icemaker. If you normally add the pink stuff, do it after the blow out procedure, but first turn off the reefer water connection and take the reefer water filter inside for the winter.
2015 335DS
