Old 10-20-2018, 12:09 PM   #11
Originally Posted by wfo9 View Post
Since you probably have a water tank under the bed, the pump is most likely right there and has a valve and suction hose to pull antifreeze directly from the bottle. Take a look it should be obvious.
Anderson valve more or less lets you go to that mode from the outside connection.
Yes the tank is under the bed and a pump is there for sure. I will look this evening for the line you are talking about. I hope itís there and Iím home free. Thank you
Mountieman is offline   Reply With Quote
Old 10-20-2018, 07:54 PM   #12
Winterizing a DX3 2018 with all electric Aqua Hot
But we are going to stay in it a lot of the winter. We need to use everything. It has switches marked "Tank Heaters" not sure when or exactly how they work? I don't know if we need to put any little heaters under either? It can get in the teens at night where we will be. Any suggestions?
tdemeyer1 is offline   Reply With Quote
Old 10-20-2018, 07:55 PM   #13
Well this did not go very well. I blew out the water lines with air but just was not satisfied so decided to use antifreeze. I made a pump system with a 35 psi pump to circulate through the fresh water inlet. All went great. I had antifreeze in every faucet and even the wet bay faucet.
Got to looking and no antifreeze had passed through the filter container. I did drain and remove filter but no antifreeze. I remember reading where the water filter only worked coming from the fresh water tank. I wanted both sides of water filter filled with antifreeze so here is where stupid kicked in.
I decided I would just pump antifreeze into FWT and then circulate with on board water pump. Well the outlet for the FWT is not on the bottom so wasted a lot of antifreeze. I then found the water pump and like WFO9 said there was a spare hose and a valve there but I only had a half gallon left. I tried to pump from the container but the pump would not draw from the container so I had to use a funnel and pour antifreeze into the pump through the line. Would like to say it worked but I ran out and will have to try and continue tomorrow.
A couple of questions. Why in the heck does this water filter not have a bypass and does all of what I have said make sense? Should the pump not have drawn the antifreeze out of the container without me having to pour it in? Why does the water have to come from the FWT to circulate through the filter and the lines on both side of it? If you pump antifreeze through the fresh water inlet, why does it never get to the water filter and the lines on both sides of it?
2019 Dynamax Force TSHD
Old 10-21-2018, 10:49 AM   #14
Don't know the specifics of the setup, but that is odd on the filter.
On my RV the filter only does water going into the coach to either supply city water or to fill the tank, there is no further filtering.
When you tried to suck anti freeze into the pump, did you flip the valve to bypass the tank. It probably will require some gravity to get it primed the first time if there is no fluid in it.
wfo9 is offline   Reply With Quote
Old 10-21-2018, 10:55 AM   #15
GM
bclemens's Avatar
1. The DX3, Force and Isata 5 do not have an Anderson Valve.
2. The pump likely did not draw antifreeze because you had already blown out the lines, so it was not creating suction/prime. You really need to do that with water in the lines for best results.
3. no water filter bypass because that needs to be winterized as well. I think they do make a cap for it...but not sure.
4. We have seen a few of the "winterization valves" installed wrong.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-21-2018, 11:01 AM   #16
The boss man working on Sunday. You must have read where I was gonna do this and thought you better check so I didnít blow something up.
Next time it will be a simple process. I did all the stupid stuff this time.
But I did relieve the pressure on the Truma before pulling the plug unlike somebody else we know.
Old 10-21-2018, 11:02 AM   #17
GM
bclemens's Avatar
phhhfttt....yeah, those dummies that forget to relieve the pressure! Ha!...I'm surprised they're allowed to even own tools.
Old 10-21-2018, 11:39 AM   #18
Oh yea, before you try sucking.... LOL Make sure you have the sinks or whatever open to take away head pressure, should still work with the lines clear but some flow pulling would help.
Old 10-21-2018, 03:28 PM   #19
hook47's Avatar
On my DX3 RB, the water tank is in an outdoor bay and the pump is under the refrigerator, almost accessible. What I did was buy a 3 way valve from HD/Lowes and spliced it in the feed line from tank to pump near the tank. Simple install and added some hose to put in an RV antifreeze bottle. Had not blown out lines so didn't take much to prime. Removed the filter cartridge before I pumped antifreeze. Carbon filter removes the red dye which makes knowing if antifreeze has filled the line with enough concentration difficult. Also need to remove filter from Fridge unless your fridge needs a filter to flow water into dispenser and ice maker as mine did. Just had to feel/taste fluid coming out of fridge water dispenser to know it was coming out. Kept that old filter to reuse this winter.
2018 DX3 37RB - 2017 Jeep GC Summit towed
hook47 is online now   Reply With Quote
Old 10-21-2018, 03:42 PM   #20
Well job now complete. First time always sucks trying to find what you need and exactly what valves do what. Thanks for all the help guys.
winter
