Originally Posted by milkman55
The valve mentioned above is behind the drawer under the kitchen cooktop.
HELP! ASAP - So we pulled out the drawer and we see two shut off valves. One shut off valve is connected to a red tube and is labeled Hot water outlet and another shut off valve is connected to a blue tube and is labeled Cold water inlet.
Is there another single hot water heater bypass valve?? OR is it one or both of these valves mentioned above that we should shut off. Can you send a photo of this bypass valve if it is different from the two mentioned above. Need a visual because we are seeing no other valves besides those two behind the kitchen drawer.
Newbies here, We greatly appreciate everyone's help!!!!!
