Old 10-13-2016, 11:16 AM   #1
Delco Bobby's Avatar
Winterizing REV
Can someone tell me how to get antifreeze into my REV water lines? No gravity fill.
It looks like I should use the "sanitize/winterize" setting on the water valve to draw the antifreeze into the system. I want to confirm that. and also that I hook up the draw hose to the CITY water inlet.
Thanks,
Bob
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 10-14-2016, 09:27 AM   #2
GM
bclemens's Avatar
Yes. Use the city water connection, turn the valve to "winterize".
A short cut off hose end can be put into a jug of antifreeze, coupler end onto the city water connection of course. The Pump then draws the antifreeze in, bypassing the water tank. If for some reason you want or need to put anything in the fresh water tank...just use a siphon mixer. They sell them on Amazon.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-14-2016, 10:39 AM   #3
Thank you.
2018 Ford F-150
winter
