Closed Thread
Old 11-01-2012, 01:32 PM   #121
Just a quick note as I purchased a 24" from Amazon with a built in DVD player for my daughter... We are going to put a second mount in the bedroom location so we can move it around... it was only about $200.00 from Amazon.
Jdulworth is offline
Old 11-05-2012, 07:08 AM   #122
Here to Help
Originally Posted by Ragin Cajun View Post
FYI...If you plan on removing the TV when your traveling, make sure you have room to slide the unit up and out of the bracket. When you take in consideration the size of the TV and the limited space between the top of the window to the top of ceiling, it'll be tight with some units.
Great input.
Our support in the sidewall is desgined to hold the weight of a 22" TV (max).
SabreSam is offline
Old 11-06-2012, 08:47 AM   #123
What kind of wood??
SabreSam,
I'm planning on adding some selves in and around our Medicine Cabinet in our 32 RCTS and would like to use the the same kind if possible. Can you tell me what kind of wood was used? and maybe some info on the stain. Can I purchase color matched stain from Palominio??
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline
Old 11-06-2012, 08:55 AM   #124
Originally Posted by SimchaSabre View Post
SabreSam,
Don't have a Sabre but here is what we did.
Name:	3 Shelves on Medicine Cabinet.jpg
ID:	21429   Click image for larger version
Name:	Curved Wall Shelf with clothes hooks.jpg
ID:	21430   Click image for larger version
Name:	Handy for misc. small items.jpg
ID:	21431   Click image for larger version
Name:	Shelf matches other woodwook.jpg
OldCoot is offline
Old 11-06-2012, 03:47 PM   #125
Here to Help
SabreSam,
Sorry typing from cell phone
The cabinet doors are oak. Any oak should have a similar grain. we do not sell matching stain. Matching panels can be purchased from any sabre dealer. hope that helps.
SabreSam is offline
Old 11-06-2012, 04:40 PM   #126
Knowing that it is oak will help a lot. We have a lcoal paint guy that can do a stain color match
Thanks sabre sam
Cathy & Jeff
Midland, Michigan
Old 11-06-2012, 04:59 PM   #127
poppy127's Avatar
Thanks sabre sam
I want pics when done so I can copy..lol
Happily Camping in Michigan!
Previous Camper: 2010 Outback
Nights Camped in 2012: 24
Current Camper: 2013 Sabre 32-RCTS-6
Nights Camped in 2012: 11
Nights Camped in 2013: 21
poppy127 is offline
Old 11-06-2012, 06:59 PM   #128
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by SabreSam
Dear Ragin Cajun,
thanks for waiting for the answer. This post applys to any Sabre model that was built with the washer dryer cabinet in the master bedroom.
http://www.forestriverforums.com/for...1&d=1349989310
These pictures show the TV installed and removed showing the bracket. So you would want to mount your bracket in the same locations. When facing the bracket the left edge of the bracket measures 42 1/2" from the face/front of the wardrobe. The bottom edge of the bracket measures 34" from the top of the dresser.
I hope this helps. DO NOT USE LONG SCREWS OR YOU WILL GO THROUGH THE SIDEWALL.
SabreSam
I need a recommendation of where to purchase the TV mounting plate as seen in your photo.
I've searched but could not find that specific mount and bought another style to use but when I got it, it's way overkill and the mounting bolts would go through the wall.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 11-07-2012, 09:27 AM   #129
rpresley's Avatar
32 rcts bedroom slide
When we picked up our 32rcts the salesman demonstrated that the bedroom slideout hangs up at the top and eventually forcefully pops free. He said it was scary but normal. We have now taken the rv on two weekend trips and the slide out issue has gotten worse. I was unable to get it to return to the in position with out bouncing on the floor while tugging at the top in order to break it free while my wife operated the switch. If I did not do this the bottom came in and caused the whole slide to be at such an angle I was fearful damage may have occured.
It will be going back to the dealer for repair. I was wondering however if this is a common issue and if I perhaps may have damaged something by having to force the top to release. Aside from the slideout problem the trailer has been great. Every thing we expected and are very satisfied.
rpresley is offline
Old 11-07-2012, 12:11 PM   #130
We have not seen this issue with our 32 RCTS bedroom slide.
Cathy & Jeff
Midland, Michigan
Closed Thread
factory, sabre, warranty
