Closed Thread
Old 11-27-2012, 08:12 AM   #141
wowzer's Avatar
New member...first post. Purchased a 34reqs6, would like to pull a trailer behind it for a Burgman 650 scooter. Will mounting a reciever hitch on the back be doable? Weight of scooter and trailer around 700-800 lbs.
wowzer is offline
Old 11-27-2012, 08:31 AM   #142
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by ependydad
Different model, but similar problem with the sofa bed in our bunkhouse. Due to the raised slide edge, the 4 legs of the bed frame don't make contact with the floor.
I spoke to SabreSam one time and he offered up a solution to help. However, we've gone ahead and made 4 blocks and drill out spots to counter-sink the bed feet.
Thanks for the tip
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 11-27-2012, 09:13 AM   #143
Fulltime family RVer
Cajun, the other thing - we looked at getting 1" coupler nuts to extend the feet so that they would be long enough to reach the ground. I had a hard-time finding the metric size/threads of what our sofa had so we didn't go that route.
We haven't used the counter-sunk blocks yet, so I can't tell you if they'll tip or not. But, I can tell you, the counter-sinking is required, otherwise the blocks will walk out from under the feet during the night. My first attempted was without and they definitely walked.
ependydad is offline
Old 11-30-2012, 12:13 PM   #144
Here to Help
Dear Wowzer,
Keep in mind the frame manufacturer will void the warranty on the frame if you weld anything on it.
"This is my opinion not that of Forest River"
SabreSam is offline
Old 11-30-2012, 12:18 PM   #145
Here to Help
2012 TV backer
Originally Posted by Cyoul8r View Post
I have a 2012 Palomino Sabre 32RCTS and want to install a 24" LG TV
(8 lbs.) to the wall just above the dresser window in the bedroom. Can you tell me if there is sufficient backing in the wall to hold it and if so what is the approximate size of the backing? There is already a cable outlet and a 120v outlet on the side of the dresser so I'm assuming this would be an option during the build of this unit. It seems as though there is some backing support but only in the center area above the window. Maybe I could locate a mount that will install only to this center area and not to the sides of it where it seems to be hollow. I saw your pictures but they were of a 2013 model. My model (2012) does not have the connections on the ceiling but instead on the side of the dresser. Will there still be backing support preinstalled? Any help is appreciated. Thank you.
Dear Customer,
Your unit does not have the backer in the wall. The origianl intention was to have the TV on your dresser. Sorry, I can't be more help.
SabreSam is offline
Old 11-30-2012, 12:24 PM   #146
Here to Help
Originally Posted by Ragin Cajun View Post
SabreSam:
The sofa air bed combo in the Sabre 32RCTS, is it suppose to be anchored to the floor?
Ours isn't and when we use the air bed, the sofa bed rocks back and forth unless we stack some books under the four metal legs of the bed frame.
BTW...the air bed works great and we really like the inflate/deflate mode on the built in electric air pump!
Dear Rajin Cajun,
First, no it should not be anchored to the floor.
I need a little more information to help. When you fold out the bed, does the most outward frame legs touch the floor? If not, how much are they short? Can you get me a photo or measurement?
SabreSam is offline
Old 11-30-2012, 12:34 PM   #147
Camper Less Camping
Originally Posted by SabreSam View Post
Dear Rajin Cajun,
SabreSam
No, the outward most metal legs do not touch the floor, when you push down that end of bed so they will touch...the wooden legs of the sofa near the window come off the floor. When my kids were in the bed, I used no more than about 2" of books under the metal legs to make sure the bed remained level so it wouldn't rock.
Old 11-30-2012, 02:54 PM   #148
Sam, think of it as a giant teeter-totter. If the bed feet are on the floor, the back feet of the couch are in the air and vice versa.
Old 12-01-2012, 09:53 AM   #149
Here to Help
SabreSam
Ok...PM me your vin number, full name and phone number and we will get you handled.
SabreSam is offline
Old 12-01-2012, 03:00 PM   #150
Cyoul8r's Avatar
Dear Customer,
Thanks for your reply Sabre Sam. If I don't have the backer board it seems as though there is a stud behind the wall above the center of the window. Can you confirm this? How wide are the studs used in this model?
CYOUL8R
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline
Closed Thread
factory, sabre, warranty
