Closed Thread
Old 12-03-2012, 03:16 PM   #151
Here to Help
Originally Posted by Cyoul8r View Post
Thanks for your reply Sabre Sam. If I don't have the backer board it seems as though there is a stud behind the wall above the center of the window. Can you confirm this? How wide are the studs used in this model?
CYOUL8R
Dear Customer,
there is a vertical stud, but I'm not sure how to give you a measurement of it's location. The Stud is 1" wide.
SabreSam is offline
Old 12-04-2012, 10:19 AM   #152
Cyoul8r's Avatar
Originally Posted by SabreSam View Post
Dear Customer,
Thanks SabreSam. My stud finder shows the vertical stud above the window to be approimately 2" wide. It measures 41"- 43 " from the washer/dryer cabinet. If I may ask one more question...do you know if the stud is wood or is it part of the aluminum framing? I plan to use 1 1/2" screws as it looks like the wall is about 2" thick. Your help is appreciated.
Bob
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline
Old 12-04-2012, 11:20 AM   #153
Here to Help
Bob
If you are screwing into the sidewall, all the frame/studs are aluminum tubes.
SabreSam is offline
Old 12-05-2012, 11:39 AM   #154
Cyoul8r's Avatar
SabreSam, thanks for all your help on my bedroom tv install. Finally got it completed and everything was good.
Cyoul8r
Cyoul8r is offline
Old 12-11-2012, 09:31 PM   #155
LaydBack's Avatar
Dear Ragin Cajun,
thanks for waiting for the answer. This post applys to any Sabre model that was built with the washer dryer cabinet in the master bedroom.
http://www.forestriverforums.com/for...1&d=1349989310
These pictures show the TV installed and removed showing the bracket. So you would want to mount your bracket in the same locations. When facing the bracket the left edge of the bracket measures 42 1/2" from the face/front of the wardrobe. The bottom edge of the bracket measures 34" from the top of the dresser.
I hope this helps. DO NOT USE LONG SCREWS OR YOU WILL GO THROUGH THE SIDEWALL.
Thanks for all of your advice SabreSam. I noticed in another post that you stated that the backer in the wall is designed/rated for a 22" TV. Can you interpret that to a weight range? I've got a larger TV in mind, but I think it only weighs about 12-13 lbs. Thanks
LaydBack is offline
Old 12-12-2012, 08:48 PM   #156
Here to Help
Dear Customer,
I've asked the plant to respond to your question. I will get back with you.
SabreSam is offline
Old 12-14-2012, 07:49 AM   #157
Here to Help
Bedroom TV Weight
Dear Customer,
My warranty department say the wall limit for a bedroom TV is 10 lbs.
I hope that helps.
SabreSam is offline
Old 12-15-2012, 07:56 AM   #158
LaydBack's Avatar
Again thanks. Would it be safe to assume that horizontally, the backing in the wall runs from stud to stud?
LaydBack is offline
Old 12-15-2012, 07:13 PM   #159
LaydBack's Avatar
Forgot to ask if there is any backing for mounting a tv in the bunkhouse of the 36qbok.
LaydBack is offline
Old 12-15-2012, 07:39 PM   #160
Fulltime family RVer
Yes there is. Just push on the back wall and you'll feel it.
ependydad is offline
Closed Thread
factory, sabre, warranty
