Closed Thread
Old 02-13-2013, 05:57 PM   #251
Fulltime family RVer
Originally Posted by Wiscampsin View Post
It did happen!! Looks nice.
X2- inspires me to finally hang ours.
Ragin, any reason why you take it down for travel? Not moving it each time we setup is one of those reasons I want to mount it.
ependydad is offline
Old 02-13-2013, 06:30 PM   #252
Camper Less Camping
Cajun Po-Boy's Avatar
Though the TV is light, you can't use long screws to anchor bracket...so I feel there's more opportunity for it to get ripped out of the wall going down the highway.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 02-13-2013, 07:01 PM   #253
phat phrog stunt crew
ok electric/air conditioner gurus..... if i add the second a/c, will i have to upgrade any of the wiring/electrical box/etc? am i safe to assume that my 12 sabre 5th wheel is ducted to the bedroom as well? will 30a run both at the same time, or will i need to be hooked up to 50a or just use 1 or the other?
dwaynerz is offline
Old 02-13-2013, 07:05 PM   #254
TURBS's Avatar
If its 50 amp prep which your spec sheet will show your fine.
If its 30 amp you'll have to run a separate cord as another has done on this forum.
It would be a pain and expensive to rewire for 50 amp.
No you cannot run two a/c's off of 30 amp.
It will be ducted to bedroom yes.
TURBS is offline
Old 02-13-2013, 07:06 PM   #255
If you PM SabreSam with your VIN, he can to you fo shizzle (aka "for sure").
Old 02-13-2013, 07:07 PM   #256
Makes sense. Disappointing because I was hoping to save a setup step.
Old 02-14-2013, 08:38 PM   #257
36QBOK-7 Club
bigblue08's Avatar
Send a message via AIM to bigblue08 Send a message via MSN to bigblue08 Send a message via Skype™ to bigblue08
2013 Sabre 36QBOK-7
Hi I'm new to the forums, I just took delivery of our 36QBOK yesterday, I had the dealer install the Trail Air rotoflex hitch on it as a dealer add on. They ordered directly from Forest River but I am not certain they ordered the right one. Is there anyone else that has the option factory installed and could look at the model sticker on the hitch and tell me what there's is? Mine seems to buck more than I think it should and it looks a little short. Thanks!!
--Jay
2008 Chevy 3500 LTZ DRW
2013 Sabre 36QBOK-7
B&W Turn over ball and companion
Days Camped 2012 - 76
Days Camped 2013 - 7
bigblue08 is offline
Old 02-15-2013, 08:40 AM   #258
Here to Help
Dear Bigblue08,
give me some time today and I will see how we can verify the unit you got. You might goto Lippert's website; Lippert Components, Inc. and compare the information to what they show there.
What numbers are on your pinbox/roto flex?
SabreSam is offline
Old 02-15-2013, 09:42 AM   #259
Here to Help
Bigblue08,
Sabres are currently built with a 1621 pin box. Per the Lippert website, part #160468 is the Roto flex to replace the 1621. I'm not sure where you would see that part number or how to check it.
Please do keep in mind the Roto flex does let the fifth wheel have more forward and back motion due to the hindge of the mech. If you are use to a fixed pin, you will see much more movement than you are use to. The rubber material in the roto flex absorbs the vibration of the "bang" front to back as where a solid pin's "bang" is vibrated thought the unit.
I hope this helps.
SabreSam is offline
Old 02-15-2013, 11:25 AM   #260
TURBS's Avatar
I recently looked at a 2013 32bhok and noticed the rotoflex.
Wondered how they'd pull.
TURBS is offline
Closed Thread
factory, sabre, warranty
