Closed Thread
Old 03-17-2013, 01:09 PM   #321
TURBS's Avatar
TURBS is offline
Old 03-17-2013, 01:17 PM   #322
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by f1100turbo View Post
Ragin,
I have a set on mine "bal" and they will not go all the way up without binding....
I just bring mine up till they touch then stop.
There maybe only an inch fresh normal nesting .
I always run the jacks so I'm not concerned.
I thought about revising them but have not looked into it yet.
The issue I'm having is the frame mount does not align with footpad, it's at an angle and binds the bar to the point where it will not be able to collapse within itself as you crank it up or down?
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 03-17-2013, 01:19 PM   #323
Camper Less Camping
Notice the frame to the left of retracted footpad...
Old 03-17-2013, 01:36 PM   #324
TURBS's Avatar
That's how mine is.
It retracts fine.
Did u take them off already ?
Did you loosen the stop bolts plenty ?
TURBS is offline
Old 03-17-2013, 01:45 PM   #325
Camper Less Camping
That's how mine is.
It retracts fine.
I had bolted one arm to footpad then dry fitted remaining bar to frame location while operating jack & noticed the problem...if your's the same variance, may have to install one...
Old 03-17-2013, 02:13 PM   #326
TURBS's Avatar
Yep mine work fine .
Soooo now you have been warned lol once you install them they will not retract 100% back up.
The bars hit before they nest.
If was at home I'd grab a pic and post it.
I will be home around 530-ish
TURBS is offline
Old 03-17-2013, 02:36 PM   #327
Camper Less Camping
If you have time one day, shoot me a pic looking back in the same direction as my pic above, this will help me understand how yours is installed/working...I have this week to install them so no rush on picture...Thanks!
Old 03-17-2013, 02:40 PM   #328
TURBS's Avatar
No problem my phriend !
TURBS is offline
Old 03-17-2013, 06:07 PM   #329
TURBS's Avatar
TURBS is offline
Old 03-17-2013, 06:11 PM   #330
TURBS's Avatar
TURBS is offline
Closed Thread
factory, sabre, warranty
