Closed Thread
Old 04-19-2013, 07:13 PM   #371
They are the multiple led.
hutchie11 is offline
Old 04-19-2013, 07:22 PM   #372
TURBS's Avatar
My 2011's went out within the first year or started blinking and had indvidual leds go out.
TURBS is offline
Old 04-19-2013, 07:23 PM   #373
TURBS's Avatar
Are you sure they have power going to them ?
TURBS is offline
Old 04-19-2013, 07:36 PM   #374
I am not sure they were working and just stopped
Old 04-20-2013, 02:14 PM   #375
TURBS's Avatar
Yeah you better get your volt meter out and check.
Odds of both lights going out simultaneously are astronomical.
Especially leds.
Turbs
TURBS is offline
Old 04-20-2013, 06:01 PM   #376
I thought there miight be a fuse located somewhere I will put the volt meter on it. Thanks
Old 04-23-2013, 06:31 PM   #377
Extende Warranty
Sam, I purchased my Sabre 34RLQS last summer but I was never told about the one year Factory Extended Warranty. The application states that is must be purchased within ten days of sale and I was wondering if that is true or if I could still purchase it.
okietom is offline
Old 04-23-2013, 06:34 PM   #378
TURBS's Avatar
In most cases it has to be very close to purchase the date.
Some have suggested if its later like 2 or 3 months to send in the form and check and if they return then you know for sure.
IF they don't then they must like you lol !
turbs
TURBS is offline
Old 04-24-2013, 12:47 PM   #379
Here to Help
Dear customer
the 10 days is the deadline. I am sorry the selling dealer did not inform you about the second year.
SabreSam is offline
Old 04-25-2013, 12:07 PM   #380
Cyoul8r's Avatar
Gray Water Holding Tank Size
Hi Sam,
Question 1
I hope you can help me with a problem regarding the size and capacity of the holding tanks on my 2012 Palomino Sabre RCTS-6. My gray water holding tank #2 developed a leak (crack) recently near where the drain fitting enters the tank on the side. The RV repair shop is ordering a replacement tank with the dimensions of 63x24x7 with a capacity of 32 gallons as stated on the work order. The original tank has an Ameri-Kart part #HT292, which the shop used to order from. My Sabre brochure states that all the tanks (4) are 42 gallons. They told me that the capacity is determined by using 231 cubic inches per gallon which would make the above dimensions equal just over 45 gallons. Is this something I should be concerned about?
Question 2
This tank was apparently leaking for some time as there was a lot of water trapped above the belly skin. Would it make sense to drill some small holes in the belly skin to allow for drainage if this was to occur again with any of the other tanks because it appears that the belly skin has been stretched out from the weight of the water?
Question 3
Also, can you tell me what drains into each of the gray water tanks?
The best I can figure out is:
Gray Tank #1 - Bathroom sink, shower, washer
Gray tank #2 - Kitchen sink
Sorry for asking so much but you have helped me in the past.
And as always, thank you for your time and knowledge.
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline
Closed Thread
factory, sabre, warranty
