Closed Thread
Old 08-20-2013, 07:49 PM   #441
BombDoc's Avatar
Originally Posted by BombDoc View Post
Must be a 12-13 change on my good slide you can see almost all of it. Stand by, I'll post a pic of the good side. Brb
I was wrong here, you can barely see any of it.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline
Old 08-20-2013, 07:51 PM   #442
rowdydog77's Avatar
Just went out to do what BombDoc had suggested....the plastic piece is part of the floor ...not the slide! It does not move with the slide. So.... mine has come loose from the floor. Now..how to fix?
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline
Old 08-22-2013, 07:09 AM   #443
BuckeyeChuck's Avatar
I had the same thing happen to my dinette side slide. I took it back to the dealer to be repaired. When I picked it up they told me it was a bigger job than they thought it would be. I guess they had to almost remove the slide to repair it. From what I gather it's there to protect the edge of the floor of the main unit while the slide is retracting.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is online now
Old 08-22-2013, 07:58 AM   #444
LaydBack's Avatar
I have a 2013 36QBOK. Is there a reflective decal/mirror for the front cap, that would help with aligning when hitching up? Thanks
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline
Old 08-22-2013, 08:43 AM   #445
TURBS's Avatar
Older models had them.
Pm oldcoot he has made one that sets on the pin box plate.
He has pictures.
Turbs
TURBS is offline
Old 08-22-2013, 08:51 AM   #446
He has pictures.
Turbs
What I have won't work on the fiberglas cover on the pinbox. It has to sit in the holes on the Reese Revolution pinbox.
OldCoot is online now
Old 08-22-2013, 07:58 PM   #447
Here to Help
Here is one pic. Me holding the carpet flap up and you can see how this was supposed to be held in place by the screw hole that has popped through the plastic.
This is with it pushed back into place. Just sitting there.
Dear Customer
You need to have this fixed by a dealer ASAP. Moving it in and out can cause damage.
Sabres am
SabreSam is offline
Old 08-22-2013, 08:06 PM   #448
Here to Help
Originally Posted by rowdydog77 View Post
Sabre Sam,
I have a 2013 Sabre Silhouette 291BHTS. I am getting ready to go on a 3 day weekend trip and noticed this from under the main slide.
The white plastic piece with the holes in it is what concerns me. The slide moves in and out freely as far as I can tell. Part of it is coming out from underneath the slide. Something has come loose from under the slide. What is this part attached to? What is it supposed to do? What happens if I continue to use the slide?
Thanks for your help.
Dear customer,
Your slide out glide bar has come loose. It needs fixed ASAP. Running the slide out in and out without this can damage things. See a dealer as quick as you can.
Sorry for the delay.
Sabresam
SabreSam is offline
Old 08-22-2013, 08:16 PM   #449
QCCowboy's Avatar
Not sure if this will help you or not LaydBack, but I have taken the center headrest out of the backseat (nobody sits in the middle anyway.) Made an immediate difference in my ability to see when hitching. I also only try to get it within a certain range from left to right. The hitch plate in the truck moves side to side and when I back in. As long as I am in close enough range it goes right in and locks in place.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline
Old 08-23-2013, 09:19 AM   #450
5 hole's Avatar
Sabre Sam
I read in this long thread about the Factory PDI being random, but having an option to request your unit being built to go through this PDI. Is this correct? If so I would be interested in this as I have recently ordered a Sabre via dealer.
5 hole is offline
Closed Thread
factory, sabre, warranty
