Closed Thread
Old 11-27-2013, 12:08 AM   #501
jtstromsburg's Avatar
Sam. I have a Question about the plumbing construction on my Sabre 34TBOK. We have a couple more weekends to use it this winter here in central Nebraska, so the heat is left on at 60 to keep everything toast. The water heater is also on. the problem has been the kitchen water lines are frozen in mid teens temperatures.
Last night, I cut an opening in the coraplast underbelly cover too see what was up. I was quite surprised to find the lines sitting directly on the "radiant" insulating layer. I had assumed the regular insulation would have been below the lines as well. Can you clear up that construction for me? Also, how is heat supplied to the underbelly?
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline
Old 11-27-2013, 10:23 AM   #502
TURBS's Avatar
Joel,
This may help some.....
TURBS is offline
Old 11-27-2013, 10:36 AM   #503
Thanks turbs. I emailed Sabre as well. In my iddy bitty bird brain, I had pictured the insulation all below any water lines and tanks, but it seems as though the only insulation below is the "radiant insulation technology" (foil bubble wrap )
Joel and Teresa
2016 Sabre 34TBOK
Old 11-27-2013, 12:14 PM   #504
Thanks to Sabres excellent customer service, I got a very quick reply from my email to Gary there. All is normal and he answered my questions quickly. Next spring I will drop the underbelly and add more insulation, and possibly some heat tape?.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-27-2013, 12:27 PM   #505
TURBS's Avatar
Gary is top notch!
He's went over and above with any help I've needed.
Turbs
TURBS is offline
Old 11-27-2013, 04:54 PM   #506
5 hole's Avatar
JTstrom.... Take photos of that process, I may need to do same!
5 hole is offline
Old 11-27-2013, 07:21 PM   #507
Will do. Thinking of asking one if my farmer friends for some winter heated shop space for a week or two. But it'll have to wait now. I'm having surgery on an ankle next Thursday and will be out of commission completely for three weeks, then 6 more with a boot. Gonna go stir crazy fer sure
Joel and Teresa
2016 Sabre 34TBOK
Old 11-27-2013, 07:27 PM   #508
5 hole's Avatar
good luck with the Surgery...
5 hole is offline
Old 12-02-2013, 11:24 PM   #509
I have a Sabre 34RLQS and I am need to hook up a trailer taillight connector on the rear bumper, do you know where the easiest place to access the wiring would be ???
okietom is offline
Old 12-03-2013, 07:47 AM   #510
TURBS's Avatar
Through the taillights easiest. Not the best.
From under the underbelly prefered.
May I ask why?
Turbs
TURBS is offline
Closed Thread
factory, sabre, warranty
