Closed Thread
Old 03-20-2014, 11:34 PM   #611
cronek28's Avatar
Great!!! Thanks again both of you. I've attached two images of my soon to be camper to show what I mean about not being angles. Does anyone have a front end like this with a short (standard) box without a slider?
ID:	48069   Click image for larger version
2013 Sabre Silhouette 320FQDS
2010 Puma 26FBSS (TT sold)
2007 2500HD Silverado Classic Crew Cab 6.5 box
"Duramax"
B&W companion slider
cronek28 is offline
Old 03-21-2014, 07:05 AM   #612
jtstromsburg's Avatar
Here are a couple pictures of my Sabre. Not sure if this helps, but although the looks are a bit different, I think they are more similar than it appears.
Sent by me
ID:	48073   Click image for larger version
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline
Old 03-21-2014, 07:33 AM   #613
TURBS's Avatar
It appears you have the same cap that I do on my 2011 sabre 32bhok.
I do in fact have a slider but have yet to use it.
You can in fact turn 80 or close to it but hopfully you'll never have to.
With that being said my dw ms Amy sometimes takes the truck and camper a day ahead of me so the option of sliding the 5er makes me more comfortable when she's alone.
She's been taught to use it and when she should.
Ive only had 1 instance where ive been close to needing the slider but didnt have to.
As stated before being in those tight angles isn't good anyway.
I've found there's always more than one way to skin a cat so always look at your options before backing into questionable places.
Pull further ahead and start the backing process sooner.
Turn around and back from other direction.
Take baby steps in backing to get the truck more aligned with trailer.
In short I've never regretted buying a slider as I know sooner or later it will pay for itself in one instance.
TURBS
Sabre owners united!
TURBS is offline
Old 03-21-2014, 12:25 PM   #614
Here to Help
I've pretty much bought a 2013 320fdqs Sabre Silhouette. I have a few day till my pick up date and still need to buy a hitch. I have a b&w turnoverball so I'm going with a b&w companion or companion slider. I have a 07 2500hd silverado classic crew cab 6.5 box and concerned weather I really need a slider or not.
Looking at the camper I now relize the 2013 Sabre has two different front ends. Two friends who have 5th wheels say they never need to slide because of the angle and king pin location on new 5ers. There 2010 Laredos clearly have cut angles in the front but my two model year newer camper is the one without the cut angles. My question is... Is there a noticeable difference in these two front caps? Is mine a really old 2013? Am I going to need a slider?
I wish is didnt notice the angled front because now I'm double guessing my pick, but I cant find and actual king pin locations numbers maybe its far enough forward I can still get 88 degrees with this camper? ANY and ALL advice or help would be greatly appricated!!!
Thank you!
Dear Customer
This is why I love this forum. Great Sabre owners helping others. It looks like you've gotten a ton of great input. Is there anything you need me to expand on?
Sabresam
Sent from my DROID RAZR HD using Forest River Forums mobile app
SabreSam is offline
Old 03-21-2014, 03:32 PM   #615
cronek28's Avatar
I keep going back and fore on this whole slider no slider issue and not its friday afternoon and I need the hitch Wednesday I guess I got my self in a bit of a mess. I was 100% sold on getting a slider an hour ago then I started calling around and of the four suppliers I called none of them have sold a sliding companion but lots of regular one.... now I'm thinking the other way again and I like to give local rv the sale but they are $300 more then the online guys...... I got to make a call here um.....
SabreSam can you put my mind at ease over the different front caps? Did they just change design in the middle of the year and or did did they change the profile as wheel?
Thanks again for everyone's input
"Duramax"
cronek28 is offline
Old 03-21-2014, 04:26 PM   #616
Camper Less Camping
Cajun Po-Boy's Avatar
IMO...the fix hitch will be a lot easier to resale...so try the fixed hitch with the camper for awhile and if you still feel uncomfortable with it...you'll have time to shop for a slider at your leisure & post your old hitch for sale to help pay for the new hitch.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline
Old 03-21-2014, 05:06 PM   #617
Fulltime family RVer
Good point, Cajun. The fixed Companion (especially if its a 3500) will sell like hot cakes on CraigsList.
ependydad is offline
Old 03-23-2014, 05:51 AM   #618
heavynlori's Avatar
This question is for SabreSam - can you explain why or why not the Sabre fifth wheels sometimes have the oval window above the slideouts usually at the kitchen area? Are these optional or how is it decided which units get them? Have looked at 2014 models at two dealers - dealer A had them on every one and dealer B had none at all. Dealer B could not explain why...and nothing in brochure
heavynlori is offline
Old 03-23-2014, 04:24 PM   #619
Here to Help
All if our designs offer approx. The same turning radius. I don't quote a degree because then a hitch installer moves an install forward or back and the degree changes.
I normally tell customers that after their sabre, the next purchase may need a slider. So pay now or later. Just my comment. Not sure it will ease your mind.
SabreSam is offline
Old 03-23-2014, 04:26 PM   #620
Here to Help
That window is not an option. Normally it is model specific. I'd be more than glad to verify a specific model if needed. Let me know.
SabreSam is offline
Closed Thread
factory, sabre, warranty
