Old 01-01-2015, 06:20 PM   #1
Attention Sabre owners
Just a heads up that on our Sabre 34RLQS the water line has come off the water heater twice now. While repairing it this time I noticed that they had actually used the wrong fittings on the water heater inlet and outlet. The lines on the water heater are the white reinforced hose and the fittings are for PEX line and not barbed fittings as they should be. To top it off the outlet hose was 1/2" and the fitting was 3/8". Might want to check yours just to be sure. It is an easy fix but pretty annoying having water everywhere.
okietom is offline   Reply With Quote
Old 01-01-2015, 06:33 PM   #2
asquared's Avatar
To better help others, what year is your sabre?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-02-2015, 07:31 AM   #3
2012
Old 01-02-2015, 09:16 AM   #4
Thanks for the heads up. Our REQS-6 is a 2013 but I will check it in the spring before firing it up.
Wiscampsin is online now   Reply With Quote
Old 01-21-2015, 03:38 PM   #5
BuckeyeChuck's Avatar
Our 33ckts is a 2013 and I'll be sure to check in the spring also.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 01-21-2015, 04:15 PM   #6
TURBS's Avatar
I have a 2012 and not had an issue.
Going to look now.
Old 01-22-2015, 11:52 AM   #7
I have a 2011 Sabre Silhouette, 250RLUD. My problem, twice, has been at the aux. pump and shore water inlet to pump. They used the plastic braided hose and used the PEX crimp fittings. I now carry a couple of small hose clamps which I can clamp just in front of the crimp. It stops the leak and saves cutting off the crimp, especially if you are out camping, miles from hardware store when you discover the leak. I think before I start my camping season this year I will go through all the connections and hoses and replace where ever I can with proper connections and hoses.
Rod
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
sabre
