Old 01-09-2015, 09:30 PM   #1
kholmes's Avatar
cargo/bike rack on sabre 33ckts
just purchased a 2014 sabre 33ckts 5er and have a question in regards to the bike rack. how do you keep 2 or more bikes upright and stable. in the pdi today i didnt look at it that close but their is only one bar at the front of the rack. What secures the bikes from moving or bouncing around? im thinking bungee cords would't hold them securely in place. Any thoughts or advice on what some people have done?
Thanks!!
Kim & Randy Holmes
2016 F350 Turbo Diesel FX4
2014 Palomino Sabre 33 CKTS
(2012: 10); (2013: 17); (2014: 33); (2015: 43);
(2016: 37); (2017: 69); (2018: 90)
kholmes is offline   Reply With Quote
Old 01-09-2015, 11:04 PM   #2
jtstromsburg's Avatar
On mine, I used the vertical post to strap the bikes against. I know others on here had too expensive of bikes to trust that method, but it worked great for us. We fit two 26" mountain bikes and two 16" kids bikes on it with space left over. I used up to four bungees and always used one ratchet strap so I knew they wouldn't come loose. Worked for us, but I don't have any pics unfortunately.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-10-2015, 07:15 AM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
Rubber bungee straps to hold in place the bike tires to the rack and also a long rubber bungee from the post around the frames of the bikes. Also installed foam protectors between the bikes so the paint does not rub off while traveling
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 01-10-2015, 01:30 PM   #4
kevnval's Avatar
We use "ratchet straps" and pieces of foam pipe insulation between the bikes where they rub together. Have only carried bikes a few times...but it worked very well.
2015 Sabre Silloutte Select 312 RKDS
2015 RAM 2500 CC 4x4 SXT 6.4l Hemi 3:73's
Former Michelin Tire Guy
kevnval is offline   Reply With Quote
Old 02-05-2015, 11:24 AM   #5
We had two more bars and brackets made - one for each bike as we carry 3. (copied existing bar/bracket - brackets were made to bolt on. We spaced the bikes out on alternative slots. If you want more info/pictures let us know.
janice parker is offline   Reply With Quote
Old 02-05-2015, 12:16 PM   #6
Old Timer
I just removed the one on my new Wildcat...so if anyone would like to have one I'll cut you a good deal.
kentnjudy is offline   Reply With Quote
Old 02-09-2015, 09:29 PM   #7
Another adventure awaits!
HESN22's Avatar
bungee cords and ratchet straps ... enjoy your Sabre as much as we love ours ... heading to Sask in 7 wks
HESN22 is offline   Reply With Quote
Old 02-09-2015, 09:51 PM   #8
Old car's Avatar
I use bungee cords around the tire rims and the bottom channels in the bike rack. Then I use more bungee cords around the bike frames and back to the upright post. We haul two adult bikes and have hauled them numerous times without issue. As far as Florida and back to Missouri.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 02-09-2015, 11:11 PM   #9
Fulltime family RVer
Pin box bike mount.
ependydad is online now   Reply With Quote
bike, bike rack, sabre
