Old 10-15-2016, 03:06 PM   #31
Left Coast
I, while on the road, just toggle to ant or satilight
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 10-15-2016, 03:07 PM   #32
Just put a Winegard crank up on the roof. Works perfectly with a receiver from home and set it up in less than 1 minute.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-15-2016, 03:08 PM   #33
Left Coast
Stay away from trees!
Old 10-15-2016, 04:07 PM   #34
BandJCarm's Avatar
This is an ongoing issue with tons of folks. Took me a year or two to figure it out.
Some of us don't 'camp'. We "Travel in a rolling house". If you want to camp, that's great, I admire you. I'm too old and physically unable. I want tv, and I want HD. I won't live with anything less.
Even though I have Direct at home, I tried Dish just to get the automatic HD antenna (Pathway X2). Every time I TRIED to start/stop my service, DISH cancelled me entirely. I tried it 3 times over 2 years. They have no idea how to do a "Pay as you go" (Even though others clearly do it.....which makes me a dummy, I get it....but no matter, this dummy couldn't make it work). Also, if you don't find ALL 3 satellites it won't download or work most often. And where I camp, is almost always a LOT of trees.
SO, I got a good meter that finds Direct Satellites and a good tripod that is both level and stable, and now I can find Direct's satellites and take my HR-25 receiver from home (it's an extra) and get a signal just fine. Cost is nothing.......already paying for that receiver in wife's sewing room.
But if I had DISH at home, it'd be different and easier. But DISH is too hard to find an open sky site because their 3 satellites are so far apart, and Direct's 3 satellites are right next to each other. DISH has to move the physical dish to change channels if that channel is on another transponder. Plus, I will never use DISH's service again, they were more frustrating than any company I ever dealt with. With Direct, I always get technical help from an english speaking person. It helps tremendously that I have their 'protection' plan (which has already replaced a new flat screen tv, bammo), they seem to help me faster and better because of it.
and I bet I've typed all that about 9 times to different but same topics where this keeps coming back up. Figuring out how to solve this problem is easy. But no one will start up a company that makes an automatic HD PORTABLE Direct TV dish........for some reason.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 10-15-2016, 04:28 PM   #35
I had Direct for 10 years in my RV and it was great. I used it in conjunction with my Hughes Net internet dish. But, Direct would not provide mobile users with HD, only SD. Then the Direct bill started getting bigger and bigger and satellite mobile internet access starting dropping off due to the introduction of the MiFi.
When my home cable system's service became unbearable, I switched to Dish. Now I have Dish at home and on the road.
One of the biggest differences between Direct and Dish is how they handle local channels. In both cases, local channels are spot beamed. So, once you leave your spot beam, you lose local channels. Direct's solution is to sell you DNS (Distance Network Service) which will give you either the NY locals or the LA locals for a rather large price. With Dish, you can call them and request a change in location, give them the zip code you are in, and they will easily change you to the spot beam where you are located.
I do have a concern about Direct, now owned by AT&T, which is the rumor on the street is that AT&T is trying to find a buyer for Direct. If that's true, who knows what their service will be like.
Wayne Lee
Out West Somewhere
2016 Sunseeker 3050DS towing 2006 Hummer H3
WayneLee is online now   Reply With Quote
Old 10-15-2016, 04:31 PM   #36
BandJCarm's Avatar
HAHAHA. (Sorry to laugh). Who knows what the service will be like WITH AT&T????
And local channels is not why I have a portable satellite service. Only reason for local channels is tornado warnings which are only given by name of county, which I have NO CLUE what county I'm in, and to see local news which I have no use for.
FROG AR-0019-242
Old 10-15-2016, 04:35 PM   #37
Left Coast
If I select to have local channels where ever I'm at, the stick and bricks won't.....so, if there's a program on network, I just go onto antenna
Old 10-15-2016, 05:31 PM   #38
nomad297's Avatar
Originally Posted by ScottBrownstein View Post
The bonus is that will mean that a lot of RVs will begin to get HD programming on the standard 18" dish from DirecTV.
What makes you think this? They will just stop using 101 and keep using 99 and 103, still requiring an oval dish.
Bruce
Old 10-15-2016, 05:40 PM   #39
Done a lot of research on this. First off, 101 is the basis of their system and carries a ton of non-programming data. They have the current bird and two in reserve at 101. The move away from SD will allow them to drop a ton of transponders that are today dedicated to SD and local channels. Sure they will support SD, but from the newer MP4 receivers. They won't abandon the 18" market, just upgrade the receivers. The whole SD/HD local channel debacle will clean up and reduce their overhead tremendously.
2015 335DS
Old 10-15-2016, 05:44 PM   #40
Telstar's Avatar
Two things; When calling DISH ask to speak to the RV group, they should know how to suspend your account.Secondly, there are good apps to assist with manually setting up a satellite antenna. DISH for my RV is great for DISH customers, Dish Align makes it easy to setup any service. You choose your satellite configuration and it tells you what to set the angle at and you just move your phone or tablet around until the signal indicator turns green. You can get it locked in, in about two minutes.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
