09-17-2015, 05:44 PM
#21
Originally Posted by bob caldwell
...when you cut into your pipes, did you end up with an oval hole?
Cut it with a hole saw in the elbow, so draw your own conclusion. Depends on the angle you look at it as to whether it's an oval.
#22
I did not mod mine and just move the hose. I do not get the Wife to do it either. The OP was asking about Y etc. Seems we have several opinions and even Modifications to a FR engineering dump system that could be implemented. The Y is about $15 bucks and a couple 10 ft Hoses $40 so the mod is cheaper and will work if you sue the correct glue.
B and B
09-17-2015, 05:54 PM
#23
On my sabre, one is in front of the axle, and one behind. Both are covered by the slides.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
09-17-2015, 05:57 PM
#24
Left Coast
Be about a $25. or less mod, using the proper glue. Tools not included, and Kenny, that's why this is being done.
09-17-2015, 05:58 PM
#25
I'm trying to wrap my head around how this is a $25.00 mod?
I'd love a materials list @ no more then $25.00
Thanks.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-17-2015, 06:10 PM
#26
I'll have to look hard at mine.
It's still at the dealer, I should have it next week. Just waiting for hitch and second ac to show up.
2008 F350 CCSB V10
2016 Sabre 36QBOK
09-17-2015, 06:53 PM
#27
Mine's got 2 outlets... Just hook it all up to a Y and into the ground. It's easy... I've worked on mine enough already... I'm not about to make more work on it... and it's getting traded next year anyway.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
09-17-2015, 07:06 PM
#28
Left Coast
With no campground having their pipe in a standard location, you'll need to pack a couple 20' hoses, then have a place to store them. Some have the room, some don't. Some people can't get under to move hoses, and even if one could, you still need to pull the handle, unless you've got the electrical style dump valve
09-17-2015, 07:39 PM
#29
I keep my hoses safe inside my cargo bay in a rubber made bin. I have heard of problems with some fence post issues...
B and B
09-17-2015, 07:42 PM
#30
Thanks.
TURBS
2011 32bhok Sabre
I think materials are closer to 50 bucks.
B and B
09-17-2015, 07:47 PM
#31
I agree.
TURBS
2011 32bhok Sabre
09-17-2015, 07:55 PM
#32
I agree.
TURBS
2011 32bhok Sabre
Check the price on a 1-1/2" drain valve and 8' of 1-1/2" black pvc pipe and a 1-1/2" rubber connector. That's all it takes. Been there, did it.
09-17-2015, 07:59 PM
#33
Left Coast
Thanks.
TURBS
2011 32bhok Sabre
1...1 1/2 Grentec valve $13.39, 2 Grentec 1 1/2 spigot $.80, 1 2' 1 1/2" ABS pipe $2.95.......$23.52. 2 hose clamps and hose in stock... oh, plus tax. Sent me $50.....I'll send parts! And, the stuff was bought local, not off net.
09-19-2015, 08:09 PM
#34
So, been reading about the poop pump.
That might be a nice solution to the dual outlets. Join together under the frame, mount the pump underneath.
Good idea?
2008 F350 CCSB V10
2016 Sabre 36QBOK
09-20-2015, 07:18 AM
#35
Oklahoma Proud
From an actual 36qbok owner......we are on a seasonal /permanent Site so we have hard pipe untill just inches from the bayonet hookups. But during normal camping we haven't had the need to have the rear hooked up. Yes i have a Y and enough hose, but the rear gray would take weeks to fill. And even with 3 kids + extras (my 3 are 4, 7, & 14) and we get 2 weekends without dumping the rear black and it is never more than 2/3 full.
Now the front...... we have to have it hooked up all the time. The front gray will stay open all the time and we can only get 1 weekend out of the front black or maybe 2 if only a quick weekend or without some of the kids.
The middle gray or the rear gray - in the front area of tanks. This one will last for along time as its only fed from the kitchen sink.
Give it a shot, but for me if i was "tow" camping all the time, id just use one hose and just move to the rear to dump before hauling, as there isnt any real need to dump the rear tanks that much.
Good luck!!
09-20-2015, 11:00 AM
#36
I have the same hookup as Bob does and if you hook it up before you put the slide out you don't have to crawl around.
Okie
09-20-2015, 11:11 AM
#37
Left Coast
Mute point for me now, as join'n the back to front is done.
09-20-2015, 11:19 AM
#38
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-20-2015, 11:30 AM
#39
Left Coast
Granted....just try'n to keep hose(s) to minimum. Would like to use under trailer storage tubes for other things....ladder, flag pole and etc.
09-20-2015, 11:36 AM
#40
Originally Posted by MillerTime
...Now the front...... we have to have it hooked up all the time. The front gray will stay open all the time...
Only problem with this is with the tank open, you are venting the whole cg sewer system thru your trailers vent system.
