09-15-2015, 10:36 PM
Dual sewage outlets
I have never bothered with full service sites, so I am new to the whole " sewer hose hookups ".
My sabre has two drains. Do we just hook up two hoses, into a Y adapter, then into the ground?
Full service virgin.....
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
09-15-2015, 10:46 PM
Thats what you suppose to do, buy more parts for the stinky slinky. I am too cheap and seldom have sewer. I use one hose and alternate between the two tank drains.
B and B
09-16-2015, 07:25 PM
I drain one at a time but ONLY when full
Never leave the valves open.
Black tank should be drained first then greys.
Kind of pointless to buy all the extra hose and y when your only going to dump when full.
Just move the hose.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-16-2015, 07:52 PM
Left Coast
Some models like mine have the 2nd grey (kitchen) dump valve under slide. So I went with a cap for that valve that has a garden hose outlet. One could put a shut off on the hose, then open the valve, then when kitchen tank is full open shut off. My sewer hose end that goes into ground pipe has a place to hook up the garden hose, so a short piece of garden hose could be put on there,joining the two together, there-by having an enclosed system.When draining black, turn off garden hose valve, drain black, then front grey. All this depends on how long we'll be at the site as to how many dishes and so-forth the sink gets used
09-16-2015, 08:00 PM
Hard plumb the rear tank into the front and forget about moving a hose and crawling under a slide and all that crazy stuff.
09-16-2015, 08:14 PM
We mostly stay 1,2 or 3 days at one spot. with 2 or 3 adults. We have not needed to drain the galley tanks constant but maybe after several days and also the black tank. So pluming the two together for us seems like its not needed compared to such little work as switching the hoses every few days to drain..
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
09-16-2015, 08:22 PM
About 3-4 hrs work and $25 cures the problem permanently!
Older folks have a problem crawling around on their knees under a slide.
09-16-2015, 08:24 PM
Left Coast
Wife does it. what did you use to glue the stuff together at the kitchen end?
09-16-2015, 08:40 PM
Regular glue for sewer pipes, what else would you use?
09-16-2015, 08:41 PM
Who Dares, Wins
Duck tape???
2015 Chevy HD D-Max
2022 Impression 315MB
09-16-2015, 08:42 PM
Bob, I am tickled to death that I got to meet you in Nashville.
It really helps to be able to visualize your ornery face as you sit at that keyboard, drinking coffee, and spewing out morsels of humor.
Hang in there!
Max
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
09-16-2015, 08:43 PM
Left Coast
Different glue for types of pipe.....black plastic use the pvc type? and the primer?
09-16-2015, 08:44 PM
Originally Posted by doc73
Duck tape???
Sounds like a winner!
09-16-2015, 08:46 PM
Left Coast
(For those that don't know)
Most folks use the glue & primer for the type of pipe they are connecting to, you can use whatever trips your trigger.
09-17-2015, 04:57 PM
Left Coast
AVS doesn't use primer acord'n to can....ha,ha,ha!
09-17-2015, 05:02 PM
You're just blowing smoke, you're too lazy to make the mod with any kind of pipe, besides, you have to use what is compatible with what's on the trailer.
09-17-2015, 05:16 PM
Left Coast
Film at 11! If it wasn't pour'n, I'd be cutt"n.
09-17-2015, 05:19 PM
More left coast BS.
09-17-2015, 05:35 PM
Left Coast
I'm plan'n on keep'n my original set-up, but have in my hand the stuff needed to hard plumb to the front waste valves.......depends on what's called for as to which system I'll use......the kitchen grey can be done with a garden hose with shut-off attached to loose hose end.....so, install hose, pull trailer valve, open slide....don't need to deal with sewer hose for doing just this. when you cut into your pipes, did you end up with an oval hole?
