Old 09-20-2015, 05:47 AM   #1
Are we there yet.......
Pbalmer65's Avatar
Front cap insulation ????
I have wondered many time why the bedroom stays hot / cold when the rest is fine. For those that have the shoe box in the closet area. NOTE: there is nothing as far as insulation behind it. Just the vainer board of the box. :-/. This summer I put a wireless temp prob in the shoe box area and found that it was as high as 112 on a 92 degree day in partial shade.
Any camping will do. :-)
Pbalmer65 is offline   Reply With Quote
Old 09-20-2015, 08:02 AM   #2
Mantisfactory's Avatar
I removed my entire bedroom to redesign and the only insulation was a thin sheet of reflective material ,but now it in fully insulated.
Mantisfactory is offline   Reply With Quote
Old 09-20-2015, 08:10 AM   #3
R3Jones's Avatar
I know it's not the same unit but here are pictures of my old Holiday Rambler Aluma-Lite. I had a stress crack in the front ABS plastic cap. It was less expensive to replace with Filon. It was filled with styrofoam and fiberglass.
Name:   ImageUploadedByForest River Forums1442754446.016485.jpg
Name:   ImageUploadedByForest River Forums1442754485.600947.jpg
Name:   ImageUploadedByForest River Forums1442754523.281823.jpg
Name:   ImageUploadedByForest River Forums1442754563.220883.jpg
Name:   ImageUploadedByForest River Forums1442754583.696190.jpg
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 09-20-2015, 03:56 PM   #4
Pbalmer65's Avatar
Update. Click image for larger version
Name:	ImageUploadedByForest River Forums1442782564.129365.jpg
ID:	89382Click image for larger version
Name:	ImageUploadedByForest River Forums1442782582.509819.jpg
ID:	89383Click image for larger version
Name:	ImageUploadedByForest River Forums1442782595.560989.jpg
ID:	89384Click image for larger version
Name:	ImageUploadedByForest River Forums1442782615.229024.jpg
Old 09-20-2015, 04:23 PM   #5
Oklahoma Proud
MillerTime's Avatar
Nope. Doesn't look like much was there. I guess i might have to insulate in there some day.
Old 09-21-2015, 02:36 PM   #6
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Here's a picture of our 5th wheel being built. Lot's of insulation there as you can see. I suppose there are many variations from model to model.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 10-16-2015, 07:10 PM   #7
Swift2
Swift 2's Avatar
Took the shoe box cabinet out and installed 6" fiberglass on all surfaces in front cap and wall. Big difference in temps. Thin existing glass hanging from top had big gaps that made it very breezy. 😳
Swift 2 is offline   Reply With Quote
Old 10-16-2015, 07:24 PM   #8
Pbalmer65's Avatar
This is my fix...Click image for larger version
Name:	ImageUploadedByForest River Forums1445041410.683630.jpg
ID:	91817Click image for larger version
Name:	ImageUploadedByForest River Forums1445041432.778485.jpg
ID:	91818Click image for larger version
Name:	ImageUploadedByForest River Forums1445041460.980808.jpg
Old 10-16-2015, 07:28 PM   #9
Always Learning
I'm slow ... can you explain what you did here? It looks like you out insulation in the front cap and then closed off the shoe box?
Old 10-16-2015, 07:41 PM   #10
Georgia Rally Coordinator
aceinspp's Avatar
Well in most cases this not a lot of insulation. It's par and not a lot to be expected of it. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 10-16-2015, 08:55 PM   #11
Pbalmer65's Avatar
This radiant barrier product has a R9 value. Light weight and easy to install I sprayed 3M glue and applied it to the cap and rolled in around the corners and top to close in attic and side wall gaps along with the floor cavity. Thinking anything larger would settle in time and not hold to the walls.
insulation
