Old 06-21-2016, 10:36 AM   #1
alsimmon11's Avatar
Heat and A/C
While out camping I decided to check the furnace. When I turned on the front living furnace I got good heat from all the vents to include the bedroom. I assume it only has one furnace. The issue I have is the A/C vents also came on blowing air from them. This happens in the bedroom also. Is this normal with the 2016 Sabre 330. My dealer is telling me that's how it works. Did not work like this with my previous rigs.
alsimmon11 is offline   Reply With Quote
Old 06-21-2016, 10:44 AM   #2
Pickin' & Campin'
A common question here and you will find with a search there are many posts about the A/C fan running with the furnace.
Set the fan mode to AUTO on your thermostat to keep the A/C fan from running with the furnace.
Side note: Many folks actually like the A/C fan running... since heat rises... it distributes the heat more evenly.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-21-2016, 03:50 PM   #3
On our Sabre we keep the fan on High when using the AC and Auto when using our furnace.
Old 06-21-2016, 08:49 PM   #4
alsimmon11's Avatar
Thanks, got a trip planned next week will give it a try.
