Old 11-11-2015, 12:05 PM   #11
Hey Bob, where do you get this stuff?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 11-11-2015, 12:12 PM   #12
Left Coast
It's been a couple years, but I think if you type in Led light strip track, you'll find it.
Old 11-11-2015, 12:32 PM   #13
Niel's Avatar
I bought an ip68 strip from Montreal Led. They said to silicone the 3m tape on to the back, let it dry and cure then stick it to the side of your rv. Clean the area with rubbing alcohol first. The strip came 5 meters long but you can cut it if need be.
Niel is online now   Reply With Quote
Old 11-11-2015, 01:18 PM   #14
Left Coast
Whatever you do, leave the tape that came on the strip on as it is also an insulator against short'n out the strip....if you use the channel.
Old 11-11-2015, 01:53 PM   #15
I also purchased Montreal led and the adhesive back did not stick in warm weather either,fine when cooler. I used,as the manufacturer suggested, GE SILICONE, very thin application, placed the strip and secured it with painters tape for a couple hours and it hasn't moved yet.
gunpro is offline   Reply With Quote
Old 11-11-2015, 01:57 PM   #16
Left Coast
When this first became 'the in mod', all these ideas were try'd. The only problem with silicone is the necessary clean up when the light strip fails...and it will.
led, light
