Old 10-01-2015, 06:58 PM   #1
BuckeyeChuck's Avatar
Lights in slide not workung.
The overhead lights in the curb side slide in my Sabre 33ckts are not working. Both the pendant lights over the table and the puck style over the theater chairs. The small light located between the windows does work. Any ideas. I checked the fuses.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 10-02-2015, 07:31 AM   #2
I would think that all the lights in the slide would be powered from the same circuit and if one of them is working then the break is most likely after that light.
I'd pull the light that's working out of the wall and see if there's wiring leaving it going to the other lights. If so then make sure you have voltage out of it.
You may wind up pulling the other fixtures out as well in order to find out where the voltage stops.
Keep in mind that it may be a broken negative wire as well.
Gotta go campin!
Old 10-02-2015, 07:50 AM   #3
WolfWhistle's Avatar
BC, are these non working lights 110vac? If 12vdc and all fuses good, I would look underneath the slide for damage to the harness at the flexible support.... both on the slide end and the trailer end. On my nearly new XLR, the flexible thing that the harness is tied to was broken off on the slide end (not installed properly IMO) and was starting to chaff the protective wiring cover (that corrogated looking black plastic).
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 10-02-2015, 08:02 AM   #4
UPDATE: I pulled the fuse out and it looked good. I reinserted it and......let there be light!
It must have been loose.
2013 Sabre 33CKTS
Old 10-02-2015, 08:03 AM   #5
Thanks for the replies.
2013 Sabre 33CKTS
light, slide
