Old 03-15-2016, 06:29 PM   #1
Maxxis 10 ply rated?
Just ordered 16" E load Maxxis tires from Discount tire. They are 10 ply rated. What is actual ply? Not sure what 10 ply rated means.
jrmorris is offline   Reply With Quote
Old 03-15-2016, 06:48 PM   #2
f5moab's Avatar
What the tire is rated for....
Good explanation...
Tire Tech Information - Load Range / Ply Rating Identification
f5moab is offline   Reply With Quote
Old 03-15-2016, 09:02 PM   #3
Fulltime family RVer
Don't know, but what axles do you have? 6,000 lbs. or 7,000 lbs?
Old 03-15-2016, 09:09 PM   #4
davel1971's Avatar
great tires. I just got some from Discounts Tires eBay store. Was even better deal than their website.
David & Lynn
Old 03-16-2016, 02:21 PM   #5
I got your PM. You can look on the white sticker on the side of the camper to know what axles you have.
The reason that I ask about axles is if you have 7,000 is that the capacity of the tires is 3,420 lbs. each. That means if you put these tires on those axles, it'll technically be underrated.
Old 03-16-2016, 02:31 PM   #6
Used to be a ply meant a ply With better materials plies were reduced but rating stayed the same. Basically a way to compare tires.
Harkerr is offline   Reply With Quote
Old 03-16-2016, 03:03 PM   #7
Pickin' & Campin'
True.
It used to mean the more plies... the more load capacity a tire had.
A load range C tire had 6 plies, a D had 8 and an E had 10.
Tire construction has changed to where that may no longer be true depending on the manufacturer.
To the OP... what load range tires do you have on now?
Days Camped: '15=22 '16=46 '17=30 '18=13
Old 03-16-2016, 05:51 PM   #8
davel1971's Avatar
How do you figure? One has nothing to do with the other. As long as the axles and tires are both rated for more than the load being applied to them, all is fine.
David & Lynn
Old 03-16-2016, 05:55 PM   #9
Yes, for the load- you're right. But, if you ever load the camper to its GVWR, you could be exceeding the tire ratings but not the axle ratings. I personally want at least as much rubber as I have axles- and more so with at least a bit of a margin.
Old 03-16-2016, 05:58 PM   #10
davel1971's Avatar
I see what your saying, but not a camper out there comes with tires rated more than the axles. As long as both meet or exceed the GVWR, and the tires are of decent quality, all should be fine.
David & Lynn
