Old 02-19-2015, 08:32 PM   #11
TURBS's Avatar
Originally Posted by asquared View Post
Welcome to the sabre family. Congrats on the new silhouette, may it bring you many happy camping memories. I am no expert on towing tandem but I do know it is illegal in some states. Other states there are length limits that a 20' boat may well put you over. Another consideration is whether or not adding a hitch will void the warranty. Just some starting points for you to look into.
It will void the warranty.
TURBS
Old 02-19-2015, 08:50 PM   #12
Congrats and welcome to the Sabre family.
Old 02-19-2015, 08:58 PM   #13
Palle man's Avatar
I live in South Dakota. It is legal and the length restriction is 75' so we are ok there. I just hope and pray that the frame is strong enough for the extra weight.
Palle man is offline   Reply With Quote
Old 02-19-2015, 09:43 PM   #14
Oklahoma Proud
MillerTime's Avatar
Congrats on your sabre op!!!
Originally Posted by TURBS View Post
I was told by a very good friend "from sabre" ABSOLUTELY NOT.
I'd agree, frame is too weak and i bet sway would be crazy with that setup. I have the sabre 36qbok and even if it was shorter with the same frame i have now, there is no way its heavy enough to pull a trailer that heavy behind it. I think the 400 lb rating on my bike rack might be too much weight if the limit was done very much. With that much load, i would bet the sidewalls would even start cracking or at least separating from the floor section.
Old 02-19-2015, 09:50 PM   #15
Palle man's Avatar
Dealer never had any concerns or mentioned anything about voiding warranty. Going to give it a try. Short trips first. Wish me luck! **** it!
Old 02-19-2015, 09:53 PM   #16
TURBS's Avatar
Dealer doesn't know what he's talking about.
Sounds as if your mind was already made up.
Like I said a sabre representative told me absolutely do not pull anything behind a sabre camper.
It will definitely void the warranty.
TURBS
Old 02-19-2015, 09:54 PM   #17
Oklahoma Proud
MillerTime's Avatar
Well at least Dont bolt a hitch to the bumper, it will just rip off....turbs has pics, i think.
Good luck
Old 02-19-2015, 09:57 PM   #18
TURBS's Avatar
Not only do you have to worry about the rear frame but also the pin box.
Pin box is not designed for that kind of pull forces.
Old 02-19-2015, 10:02 PM   #19
Oklahoma Proud
MillerTime's Avatar
Btw...whats the tongue weight on your boat, you might check it. I know my boat is pretty tongue heavy and its about the same weight as yours.
My main concern would be the boat tongue weight taking too much away from the 5er hitch weight and causing a serious sway issue.
I guess you'll find out. Stay safe!
Old 02-19-2015, 10:35 PM   #20
Palle man's Avatar
I think the tongue weight is around 300 lbs.
sabre
