Old 02-19-2015, 10:44 PM   #21
asquared's Avatar
300 lbs tongue weight sounds way low with the 4500 lb boat. I agree with the others this does not sound like a good idea towing a double axle 4500 lb trailer behind a fiver.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-19-2015, 11:12 PM   #22
Palle man's Avatar
Its a dual axle so most of the weight is on the axles. I'll find out for sure though.
Palle man is offline   Reply With Quote
Old 02-19-2015, 11:31 PM   #23
Palle man's Avatar
The boat is around 3400 pounds. I am just estimating the trailer weight.
Old 02-20-2015, 09:48 AM   #24
5 hole's Avatar
Palle man, I would take the advice of the people on here vs what 'the dealer' did, or did not tell you. Way more product specific product knowledge on here than 'your sales person'. Is it worth the possibility of the damage, or accident based on a possibly mis informed decision on your part?
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
5 hole is offline   Reply With Quote
Old 02-20-2015, 10:07 AM   #25
(Dry Huunday)
DreiHunde's Avatar
Definitely get your boat weighed.
Tongue wt for your boat trailer should be 10-15% of your total wt. I have a 22' Boat on a dual axle trailer. At the scales it is 4660 lbs with a 614 lb tongue wt.
That's a heavy load to add.
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 02-20-2015, 02:24 PM   #26
Retired
RubyDually's Avatar
Originally Posted by Palle man View Post
Dealer never had any concerns or mentioned anything about voiding warranty. Going to give it a try. Short trips first. Wish me luck! **** it!
I met a factory rep a few weeks back at a RV show and asked what would happen if I had a hitch installed so I could double tow a small trailer with a quad and got the answer I expected...
"You will void the frame warranty" was his answer...
We didn't discuss handling a second trailer that required brakes with the 5er.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
sabre
