Old 10-19-2014, 06:55 PM   #1
kevnval's Avatar
New Sabre Silloutte Black Tank Flush leak
2015 Sabre 312 RKDS....Hooked up the black tank flush for the first time this weekend.Water was going into the black tank ok...but it was also leaking out through the underbelly....through the opening that the black tank T handle protrudes through...not a drip...a pretty good stream of water. Leaked with the black tank valve opened or closed. Checked the back flow valve under the bathroom sink...not leaking there. I guess I'll have the dealer drop the underbelly to investigate...anyone have this problem?...comments?
Thanks...
2015 Sabre Silloutte Select 312 RKDS
2015 RAM 2500 CC 4x4 SXT 6.4l Hemi 3:73's
Former Michelin Tire Guy
kevnval is offline   Reply With Quote
Old 10-19-2014, 07:05 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
If you never had a leak prior to pulling the dump valve..... I would look at the oulet side of the valve and the discharge tubing. Sounds like they forgot to tighten up some screws....
donanddona is offline   Reply With Quote
black, black tank, black tank flush, leak, sabre, tank
