02-04-2018, 06:14 PM
No voltage to outlets
Im a newbie. Have a question. 2018 Sabre Colbalt. With batteries on and inverter running should I have power to the outlets?
02-04-2018, 07:26 PM
probably not. generally the inverter is only used to power a residential refrigerator. can you check to see if the refrigerator is getting power? i'm assuming you are not connected to shore power. what I have said is typical but there are always exceptions. also, a residential refrigerator can draw down batteries in a pretty short period of time. I do not know how many and what type batteries you have.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
02-04-2018, 07:30 PM
Yes the residential refrigerator is running. I am not connected to shore power. Have 2 batteries.
... "inverter running"... What are you calling an inverter? Inverter generator? or else?
02-04-2018, 07:38 PM
No shore power so I assume its called an inverter taking battery power and converting to 110 to run the frig.
02-04-2018, 07:45 PM
I have to be careful to qualify this or I'll have my answer "adjusted" but many/most/some unit's inverters ONLY power the residential fridge and no other outlets. Can you find your inverter and see how many cords are plugged in? I don't have an inverter/residential fridge so I only know what I've read.
02-04-2018, 07:50 PM
I will check tomorrow. The 5th wheel is in storage for the evening. Have a good rest of the day
02-04-2018, 07:57 PM
yep, most of those with residential fridges, the inverter only runs the fridge, not the outlets.
02-04-2018, 08:06 PM
So I need to be hooked to shore power for the outlets to work?
02-04-2018, 08:10 PM
Yes --------- or a generator.
02-04-2018, 08:12 PM
Thanks. I will hook up shore power and confirm. Have a good evening
02-04-2018, 08:51 PM
did you turn the inverter off when you put it into storage? if you left it on the refrigerator will use battery power while in storage. those batteries won't last long unless they get recharged. you say you can connect to shore power. can you do this where the unit is being stored? that would keep the batteries charged. and run the refrigerator of shore power without need to turn the inverter on. and even better would be to turn the refrigerator off. many people complain about batteries going dead while in storage even with most loads turned off.
02-04-2018, 08:55 PM
Shame on your dealer for not explaining these important systems to you during your PDI/Customer Orientation.
02-05-2018, 03:02 PM
You may want to see if your GFI is tripped. Normally on the duplex plug in the bathroom. May be an easy fix. Also turn off the refer.
02-05-2018, 03:08 PM
It's my opinion that the OP might have deciphered his problem.
02-05-2018, 03:14 PM
Originally Posted by wmtire
Those should be must-read stickys before you can ask questions
02-05-2018, 08:31 PM
120 volts on batteries
A converter boost 12 Direct Current to 120 volts Alternating Current. If you have a residential refrigerator this converted provides do the refrigerator only. Two six volt batteries connected in series provides 12 volts that is converted to 120 volts for approximately 6 to 8 hours run time. An inverter takes 120 volts and chokes it down to 12 volts DC to run lights, slides, awning and such. Generally there are two different six volt batteries that run the 12 volt DC system without shore power 120 volts. So no you will not have power on plugs except the refrigerator without shore power. Hope this helps.
02-05-2018, 08:35 PM
Uhh, the terminology (emboldened in red above) is backwards here. A converter converts 120 volt ac to 12 volt DC.
An inverter inverts 12 volt DC to 120 volt AC
This link may help:
https://www.diffen.com/difference/Converter_vs_Inverter
as well as the converter and inverter links that are posted above in posts #12 and #17.
2011 Flagstaff 831 RLBSS
02-05-2018, 08:41 PM
This didn't help
A CONVERTER changes 110 volt ac into 12 volts dc. It powers 12 volt lighting, 12 volt electric to the REF, 12 volt to the igniters for the WH and the furnace and charges the battery. An inverter changes 12 volt dc into 110 volt ac. The resi ref is connected to an INVERTER. Some TT/Motorhomes have combination Converters/Inverters.
