Old 10-20-2014, 08:54 AM   #11
Herk7769's Avatar
Originally Posted by jthoran View Post
My Sabre 31CKTS came with the cargo carrier, and is rated at 450 lb. carrying capacity. Has anyone used this to carry a 400 lb motor scooter, like a Vespa or Burgman?
What year was your Sabre made?
Never mind; I should have checked your profile.
One model offered a cargo rack for a year or so then removed the option due to frame damage claims. I don't remember which model/division it was.
Might have been Wildcat...
HAM CALLSIGN - KC3FFW
Old 10-20-2014, 07:10 PM   #12
Llewellyn Camper
So, they are saying the cargo carrier they installed at the factory with a 450lb. Load rating shouldn't be usd to carry anything more than bicycles? Is it the rack that they are worried about, or the weight on the frame or mounts?
jthoran is offline   Reply With Quote
Old 10-20-2014, 07:23 PM   #13
Llewellyn Camper
Does this mean I should replace the rack? If so, can I install a rack made for hauling a scooter on this 5th wheel?
Old 10-20-2014, 08:50 PM   #14
Oklahoma Proud
MillerTime's Avatar
My rack is rated for 450# too. I haven't hauled anything on it since I couldn't stick the pins in to lock it down till I reamed them, plus I didn't get the pole for about a month.
It is attached to the frame and not the bumper though.
If it was me, I'd get a couple of bigger kids to jump up and down on it and watch the frame flex or how the camper reacts. Depending on how that goes, maybe try something in the 2-300# range while towing and have someone else video it while you are driving over road joints and other bumps, and see how that goes.
Just an idea.....
Old 10-20-2014, 09:02 PM   #15
asquared's Avatar
Just an idea.....
We just bought smaller hitch receiver pins. We use the bigger ones to keep the rack up and the smaller ones when the rack is down. Much easier then getting things shaved to fit.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-20-2014, 09:03 PM   #16
asquared's Avatar
Careful about voiding any remaining warranty you may have.
2014 Sabre 34REQS-6
Old 10-20-2014, 09:09 PM   #17
Oklahoma Proud
MillerTime's Avatar
It just took me a couple minutes. Ran a 3/4" or whatever size it was drill bit in it. Works like it should and no play
Old 10-21-2014, 09:37 AM   #18
Llewellyn Camper
My cargo carrier rack is mounted with brackets to the frame as well. It seems pretty strange that they would install a 450 lb. rated hitch if it couldn't handle the weight, or if the frame or axles couldn't handle the weight load on the rear of the vehicle. The rack is pretty substantial; the frame mounting brackets seem to be adequate. I think I would definitely change out the mounting bolts though, as they are probably 5/16" from looking at them.
Old 10-21-2014, 12:28 PM   #19
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by f1100turbo View Post
This is the official response from sabre.
"We do not recommend it. This rack is designed for bicycles only."
Turbs
What a response from the factory...like seeing a sticker inside my (advertised) running shoes that says recommended for walking only! LOL
But...I wouldn't test the 450lb rating while bouncing down the hwy ')
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-21-2014, 04:17 PM   #20
MacDR's Avatar
I ran a 1300 mile trip with 4 bikes and an electric scooter.. I need a trailer fort 5ver..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
palomino, sabre
