Old 04-18-2014, 11:27 PM   #21
Fulltime family RVer
Woohoo! Congrats!
ependydad is online now   Reply With Quote
Old 04-19-2014, 06:50 AM   #22
Oklahoma Proud
MillerTime's Avatar
Sweet! Nice looking place too!
MillerTime- Future Sabre Handler!!
Old 04-19-2014, 07:36 AM   #23
In Search of a Vacation
cwblaylock's Avatar
Great Looking Setup!!! Congrats!
2013 GMC Denali-HD, 4X4,Diesel, Allison, Crew Cab, Dually, Demco 21K Dual Pivot 5th Wheel Hitch
2013 Sabre- 35QSIK-6 Platinum Edition, Fireplace,Wood floor, Central Vac, 13K secondary AC, Washer/Dryer Combo unit, 4 point auto-leveling, Trail-Air Suspension, Trail-Air 18K Air Ride-King Pin Box .
cwblaylock is offline   Reply With Quote
Old 04-19-2014, 07:50 AM   #24
themounties's Avatar
Nice congratulations, somewhere I saw someone had put together some of those noodles for the pool, they glued them together or something, I didn't want to snoop to much,and had those under their awning toppers looks like it worked, I would think if they were installed right you shouldn't have to worry for a few years.
themounties is offline   Reply With Quote
Old 04-19-2014, 02:53 PM   #25
Pirates55's Avatar
Been working and cleaning the camper all day. So far most thing look good.
I did find the drawer that's on the passenger side that goes under the bottom bunk doesn't close correctly. I also found the hinge on the passenger side storage compartment is stripped and coming loose. Any suggestions on fixing it? I looked about putting a small bolt with nut and washer on it but it's screwed into a metal tube. The screw holes are pretty monkeyed up. I'm not sure if a larger screw would work or not. I may try that. There is also a place on the inside trim piece way up high. I will snap some pictures when I get back out to the camper tomorrow. It started to rain pretty hard so I quit for the day.
Also, the front storage under the king pin barely latches. I've seen others with this issue and wonder if it's fairly easy to adjust the latch.
Pirates55 is offline   Reply With Quote
Old 04-19-2014, 03:21 PM   #26
QCCowboy's Avatar
To help with the storage latches barely catching, I pulled up the plate (just 2 screws) and put an o-ring in between it and the body. Closes the gap and helps keep any water out. Just a couple bucks allowed me to do all three slam latch doors (6 o-rings).
http://i1021.photobucket.com/albums/...3-30152052.jpg
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-19-2014, 03:32 PM   #27
Pirates55's Avatar
Any idea the size of that o ring?
Old 04-19-2014, 05:17 PM   #28
Pirates55's Avatar
The larger sheet metals screws fixed the gas shock where it was stripped out.
The drawer slides were not attached in the back. Pulled the drawer and reattached the drawer slides and then re installed the drawer and so far it's fixed. I guess we will see how long it holds up.
Old 04-19-2014, 05:42 PM   #29
QCCowboy's Avatar
Not sure but I can probably tell you in a couple days when I get home.
2014 Sabre 36QBOK
Old 04-20-2014, 01:35 PM   #30
Pirates55's Avatar
Thank QC cowboy. I was in Home Depot yesterday and they didn't have any o-rings other little tiny ones.
sabre
