Old 01-06-2016, 09:35 AM   #1
Kenny kustom's Avatar
Sabre 36qbok battery upgrade.
I picked up a pair of 12v Trojan J185H-AC from a guy on kijiji. ( craigslist Canada)
He had bout them for a solar project that never happened.
He had dropped the price four times, I ended up paying $350 cdn for the pair. ( 250 usd).
Now I just need to find a place to put them.
The stock battery location has a cut out for a second battery.
The battery box is plastic and hangs below the basement a bit.
I am going to remove the plastic, and make a dual box that hangs a little lower, to fit the height of the Trojans.
I will have the welding class at school, bend up a box out of either aluminum or stainless.
Flanges will be wide enough to catch the lip on the frame rails.
Anyone else with a sabre, could easily drop another plastic box, and put another stock battery behind the first one. The metal is perforated for another cut out.
Name:	ImageUploadedByForest River Forums1452090934.559574.jpg
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-06-2016, 10:29 AM   #2
TURBS's Avatar
You can buy that lipped box from sabre parts if you wanted.
Old 01-06-2016, 10:34 AM   #3
A metal one?
The stock is plastic.
Also, I need to go deeper.
2016 Sabre 36QBOK
Old 01-06-2016, 10:37 AM   #4
TURBS's Avatar
Oh no it'd be plastic.
Didn't think of the additional height.
Old 01-06-2016, 10:39 AM   #5
And weight.
125 each.
2016 Sabre 36QBOK
Old 01-06-2016, 10:44 AM   #6
Something like this.
Except longer, to fit both.
I would have to notch one corner, to fit around the landing gear. Click image for larger version
Name:	ImageUploadedByForest River Forums1452095042.963001.jpg
2016 Sabre 36QBOK
Old 01-07-2016, 09:50 PM   #7
I may put another two on the other side of the basement as well.
2016 Sabre 36QBOK
Old 01-08-2016, 12:34 AM   #8
Fulltime family RVer
But that's where I store my power tools and bar clamps...
Old 01-08-2016, 08:01 AM   #9
Mines full too!
So then, the spare tire has to go!
There's a great spot there.
Tire can go under the belly, or bolt it to the bike rack.
I have big plans for my basement!
2016 Sabre 36QBOK
Old 02-14-2016, 10:43 AM   #10
Jimsue's Avatar
Hey Turbs
Do you have a source for the Sabre parts, such as the lipped battery box? Thanks again!
Jim
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
battery, sabre, upgrade
