Old 06-01-2015, 10:59 AM   #1
Sabre aluminum frame
Is the roof access ladder fastened directly to the aluminum cage or frame? I'm needing a grounding bond for a ham antenna at the ladder, and I thought someone else might know about the construction methods.
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 06-01-2015, 11:20 AM   #2
Left Coast
Can you remove a screw/bolt and using a thin object to probe and listen for a metallic sound?
Old 06-01-2015, 11:33 AM   #3
TURBS's Avatar
I've sent an email to find out if it in fact is mounted to the "sabre cage"
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-01-2015, 11:53 AM   #4
TURBS's Avatar
I received a response back and in fact the ladder is "NOT" mounted to the aluminum superstructure.
It is mounted to wood backers.
Back to the drawing board.
TURBS
2011 32bhok Sabre
Old 06-01-2015, 12:06 PM   #5
Thanks for the blazing fast help, Bob and TURBS. I'm a little surprised though. I can bond it myself but it'll involve some kind of wall or roof access somewhere. I can see the roof frame at the nearby bath roof vent so that might help.
2006 F-250 6.OL
Old 06-01-2015, 12:08 PM   #6
TURBS's Avatar
The aluminum roof structure is on at least two sides of the roof vent.
TURBS
2011 32bhok Sabre
Old 06-01-2015, 12:09 PM   #7
TURBS's Avatar
Can you not still mount it to the ladder and run a bonding cable to the frame?
TURBS
2011 32bhok Sabre
Old 06-01-2015, 12:11 PM   #8
Fulltime family RVer
There has to be fairly accessible aluminum framing back there:
Learn To RV: Palomino Sabre Factory Tour Photos
Old 06-01-2015, 05:30 PM   #9
I can prettily easily and cleanly bond the ladder to the chassis. But does anyone know if the aluminum wall "cage" is connected electrically to the chassis? I mean would you think the 2 are bolted together? I want to rely on the ceiling framing as a ground plane for the vertical antenna. I truly appreciate all the interest as it helps me think before breaking out the cutting torch and chainsaw! It's great that DW let's me do anything I want to.
2006 F-250 6.OL
Old 06-01-2015, 05:32 PM   #10
TURBS's Avatar
Yes it is.
The electrical devices in the ceiling are grounded to it.
TURBS
2011 32bhok Sabre
frame, sabre
