Old 11-09-2015, 12:54 PM   #1
Old car's Avatar
Sabre attic vents
I saw a picture posted by Oakman recently showing the location of attic vents and black/gray tank vents on his Silverback roof. This leads me to a couple of questions.
I have a 2015 Sabre 33CKTS-6 and was cleaning the roof this past weekend. I have two vents that are for the black and gray holding tanks. I have two gray tanks but only 1 vent so I assume they are vented together. Is that a safe assumption? I do not have any attic vents similar to Oakman's picture. What I did notice is behind the rear air conditioning unit, I can tell there is a hole cut through the roof decking but it is covered by the rubber roof material. The hole is about the size of a soft drink can. I did not notice if this same condition exists behind the forward a/c unit but will get back up to check. Should I have attic vents or could it be vented in a different fashion?
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 11-09-2015, 12:55 PM   #2
TURBS's Avatar
No attic vents.
I do believe the two gray tanks are vented together.
Mine was.
Old 11-09-2015, 05:50 PM   #3
SilhouettePenny's Avatar
I found the same 3 inch hole on my Silhouette RKDS last year (2014 model) located about two feet forward of the shower skylight. Install, or have the dealer install a 5 inch vent so you don't step on that area & puncture the roof membrane.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-09-2015, 10:29 PM   #4
Oklahoma Proud
MillerTime's Avatar
On my 2015 36qbok, I have 2 attic vents and 3 tank vents on the roof and one on my rear wall. (5 tanks total) I believe my kitchen tank is not vented normally but a self-venting one since its in a bar, plus the slow way that it drains.
I would venture a guess that the attic vents were forgot after they installed the roof. My rear tank had the vent stuck into the bunkhouse because they forgot to drill the hole and run it out the rear wall. (And yes it started stinking after a month).
If there is nothing under the membrane, i would definitely get the vents installed. Thats going to be a huge water leak eventually.
sabre, vent
